Results 1 to 13 of 13
    Veteran Member Three Rings grillhands's Avatar
    May 13 2009
    home made oil restrictor
    So my gt2x only has about 400 miles on it and it's blowing smoke like crazy. I couldn't take it anymore so what i did was i got a really small washer with center hole about 3mm in diameter installed it into the oil feed line and now everything has stoppedDoes anybody know the oil pressure the 1.8t makes?
    If i throw a dog a bone, i don't want to know if it tastes good or not. Keep that in mind when you do someone a favor.
    H&R race springs|Blown shocks|WMI kit|Forge 007|630cc injectors with Eurodyne mafless tune|2.5magnaflow custom exhaust|frount mount|FX400 6puck|Brute rods| AEB pistons|Hopes and dreams.
    K03s-Fun
    GT2X KIA-Funner
    T3/T04e 46 trim .63 a/r-Funnerest
    Active Member Two Rings nheurotuner's Avatar
    Aug 12 2009
    New Hampshire
    You should just buy a restrictor why would you chance running to low of an oil pressure and seize the Turbo?
    May 13 2009
    I have to drive the car about 100 miles a day and i dont want to be that guy with smoke all over the highway. This is just for the time being until the one i ordered gets here, which should be today or tomorrow.
    K03s-Fun
    GT2X KIA-Funner
    Nov 21 2006
    san francisco, ca
    630cc injectors on a GT2X? Thats way overkill. You can tune 2871r elims on 415's.
    --dillon
    1998.5 A4 2.0TQM ADR/058, Custom ME5 tune by 034, ABA 92.8 stroke forged crank, Scat rods, JE Pistons (83mm/8.5:1), Schrick cams, Supertech springs and retainers, inconel exhaust valves (+1mm), Spa T3 mani with a Precision 5557E-B, 034 3inch exhaust, etc, etc, etc. 034 featured user
    2012 S4 Prestige, Titanium, Monsoon gray metallic, DSG. 034 ECU and TCU tunes and other bits.
    Veteran Member Three Rings discontained's Avatar
    Jul 09 2007
    '01 A4 1.8t
    GA
    here is what I found :D
    Quote Originally Posted by grillhands View Post
    Bentley says if oil temp is 80c (175f), the pressure should be:
    - At Idling speed: at least 1.0 bar (14.5 psi)
    - At 3000 rpm: 3.5-4.5 bar (50-65psi)
    For Sale $3,500 -'99 Audi A4 1.8T Quattro 5sp
    -2001.5 Audi A4 1.8T Quattromatic - BT .50 trizzle -RIP
    May 13 2009
    I wanted to keep a tune where if i decided to go bigger i can just slap the turbo on
    K03s-Fun
    GT2X KIA-Funner
    May 13 2009
    you are the man. thanks
    K03s-Fun
    GT2X KIA-Funner
    Jun 30 2008
    Erie, Pennsylvania
    I'm pretty sure with the oil cold and high revs our engines can get up to 80 or 90 psi. I had a gauge hooked up once and it got pretty high when you rev it out. I remember because I was worried the connection for the gauge would leak because I didn't tighten it down whole lot.
    Veteran Member Four Rings Lazer Viking's Avatar
    Nov 06 2006
    garage ornaments
    southeastern pa
    Quote Originally Posted by nunya View Post
    --dillon
    yea, but they wont make nearly their potential power.. elim guys can barely hit 300 with 440's but can hit well over 300 with 630's
    -Nic
    My Car
    old junk new junk, red junk blue junk
    Nov 21 2006
    san francisco, ca
    Quote Originally Posted by Lazer Viking View Post
    You can run larger injectors, sure, and potentially be able to get more power. But remember you need the air to burn the fuel. With the 4 custom tunes i had with the 5 eliminators (GT2X/2xGTRS/2x71r's) my car has seen, using 550 and 440's at 4bar, 100% duty cycle was no where to be seen. I think people tune for that injector to build all the other tunes off of. I doubt anyone would build a complete custom tune off 630's with a smaller turbo like that, which is more the point i am trying to make.
    All of my setups on pump gas never hit over 300whp until i went full frame, still using 550's mind you. But this is on 034's land and sea and another dyno dynamics which are a different beast then mustangs and dynojets.
    --dillon
    May 13 2009
    17 Camaro 1LE, 20 WRX
    Charlotte
    I have the same issue, where did you purchase the restrictor from? I feel sorry for the people in the drve thru everytime i grab some food LOL.
    NEW: B5 S4 Avant 6sp....build/refresh thread:
    https://www.audizine.com/forum/showt...1-S4-Avant-6mt
    OLD A4: GT2X--Revo 2--Hyperboost DV--380CC Injectors--TP--APR Stealth--Podi--CM FX300--Zimmerman--Hawk HPS
    Oct 06 2004
    Minnesota
    Just buy one. My car runs 60-90psi oil pressure.
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Senior Member Two Rings NoFear4285's Avatar
    Dec 11 2007
    Portland, OR
    Wow i've had the same smoking issue with my gt2x and just thought the seals were bad already but hadnt blown.. Did the oil restrictor really fix it all? Im going to go pick one up at 034 tomorrow! haha. (this thread just made my day)
    2011 Audi S4 Prestige | Brilliant Black/Magma Red | DSG |
    SOLD 2011 Audi S4 | Deep Sea Blue | DSG | Roc-Euro Intake | H&R Street Coilovers |
    SOLD 2004 Audi S4
    SOLD 1999 Audi A4 1.8TQM | GT2X Eliminator
