Ok so I changed my PCV valve and the N80 valve yesterday and sure enough both of them were broken.
I could easily blow trough the N80 which you should not be able to.
The PCV consists of atleast 2 one way valves wich both leaked and did not always shut when I blew trough them.
Pic.1
Pic.2
If you want to check your PCV try sucking and blowing in the directons of the arrows in the pictures. If it's working like it should air should only be let trough one way. You should not be able to both suck and blow in the same hole.
The result of changing these is a much smoother idle and startup and also a noticeable increase in power becuase the boost is no longer going into the valvecase.
