Results 1 to 7 of 7
    Senior Member Three Rings JeST's Avatar
    Feb 08 2010
    1995 Supra
    Zoo York
    Any DIY Guide for a window regulator?
    Drivers side window is starting to act up a bit (one touch open works fine. One touch close window rolls up then moves back down a few inches). I hear it's a complete pain as the door frame itself has to come off. Was wondering if anyone know of a DIY guide I can use. Search came up with nothing. Thanks in advance.
    Current:
    2000 Nogaro on Nogaro 6 speed B5 S4
    1994 Toyota Supra 6 speed
    '07 6spd S4 DTM Brilliant Red/Black on Black Alcantara
    '03 M3 VF Supercharged AW/Cinn
    '03 Lexus IS300 GGP GTE/6spd Getrag (615rwhp/520rwtq @ 19psi pump gas)
    Veteran Member Three Rings ZEUSROTTY's Avatar
    Feb 19 2008
    Bolingbrook IL
    I think there was one on audi world...
    2010 S4 DSG Mods None yet...
    Gone 2004 S4 Mods: tinted 25%, APR Dowpipes, w/custom custom cat back including Magnaflow x-pipe Magnaflow bullet mufflers and Flowmaster D40's . Stock intake, APR Reflash - Hotchkins Sways - Koni Yellows front and rear - H&R Springs - Goodrich brake lines - Hawk+'s - Nitto NT05's for the street and 01's for the track. 18" R8 Reps... More to come!
    Active Member Three Rings tylerS's Avatar
    Aug 02 2009
    nw
    you know there's a lot more out there besides what's on az......
    http://audiforums.com/forum/showthread.php?t=130032
    May 06 2009
    Kitchener, Ontario, Canada
    I did my driver side window regulator just by unbolting stuff until everything came apart lol. Got the new regulator in and had no bolts and screws left at the end.
    Nov 19 2008
    San Jose, CA
    Feb 08 2010
    1995 Supra
    Zoo York
    Thanks for the links.
    Current:
    Aug 29 2009
    02b6 1.8tqm,99bmw e36, Yam. R1
    Daly City
    The window Reg. isn't too bad to do. My rear driver reg. broke a few months ago and I fixed it. Pretty close to the same as the front. Looks more of a pain in the butt than it really is. Most likely the little plastic piece on the reg. that holds the cable is probally broken. I know they have a kit you can buy, never tried it though, just went ahead and bought a new Reg. from the dealer. I guess it helps to own a autorepair shop, but audi parts are still expensive.
