Results 1 to 40 of 40
Thread: brakes creaking
    Mar 15 2009
    CO
    brakes creaking
    My brakes are creaking as I pump the pedal. Its most noticable when stopped like at a light. When I'm stopped and pump the brake pedal in and out there is a very loud and noticable creak that I can hear from the front wheels and feel in the motion of the pedal. Some posts seem to attribute this sort of thing to bad fluid, but it seems very mechanical as if some part is literally creaking somewhere on or near the calipers. The "creak" can actually be felt through the pedal as if the pedal is not moving smoothly once I push hard. I dont think performance is suffering other than the feel of the brakes. Any ideas?
    Senior Member Two Rings yycools's Avatar
    Feb 09 2010
    Boston
    I have it too. Not as bad as what your experiencing. But I have new rotor and pads, and I heard it's normal to have noisy breaks on the B7s
    Veteran Member Three Rings Alkemix's Avatar
    Apr 23 2008
    2019 Lexus NX (wifes)
    Are you feeling the creaking at the pedals or you can actually hear the creaking from outside the cabin to inside the cabin you mean? Are you sure the creak itself is not coming from the brake pedal? Fluid actuates the cylinders... so it could be bad fluid, or it could be air in the lines, or it could be your brake cylinders going bad.
    I am getting this with my clutch pedal, but the creaking comes from the clutch pedal itself.
    Gone:
    2008 2.0T Quattro 6 MT Dolphin Grey / APR 91 / APR Catback / APR Intake / Sway Bars
    2013 S4 S-Tronic Black / Magnaflow / USS / STOCK
    Mar 15 2009
    CO
    no the noise is coming from the outside but I can feel a corresponding creak or like fluctuation in the pedal itself as well. Its not that significant but the noise is pretty annoying and just doesn't sound right at all. It may be water in the lines as the weather changed dramatically here today (from being stored in below freezing to it being in the 60s and 70s) so maybe something happened with the pressure difference of the fluid.
    DUH! an Audi
    los angeles, CA
    a few questions: when was the last time you did a brake flush? when did you change your pads, rotors or how many miles on them.
    I have heard a creaking sound as well before, I "solved" this by replacing the break pad clips stopped for awhile.
    Mar 15 2009
    CO
    i think the last time the brakes were flushed was around june. The pads and rotors are both from when I bought the car 2 years ago but they were new then. I've had the car serviced at regular intervals of like 6,000 miles and as of june they audi claimed my pads were still at about 70% i guess meaning 30% worn. When I had it in last week they didnt say anything so I assumed they were still fine.
    Senior Member Two Rings the700level's Avatar
    Feb 13 2010
    Philadelphia, PA
    your rotors are probably beat
    Active Member Two Rings TKKEN01's Avatar
    Feb 08 2010
    2007 A4 2.0T
    Syracuse, NY
    I've been experiencing this same issue. It didn't seem to become noticeable until the weather got a bit warmer. I get a metallic creaky sound (LOUD) when I'm stopped and depressing the brake. I can make it creak by increasing and decreasing the pressure to the brake pedal while stopped. I never hear it while driving at speed. It only seems to appear while stopped or very close to stopping speed. It's driving me nuts! I plan to have the service department take a look at it next time I bring the car in. Any others experiencing this? Any tips besides those stated above? In the meantime, I guess my baby will have to sound like a POS at every stoplight...lol
    Feb 06 2010
    1996 Nissan 240SX SE sr20DET the BEAST
    ArKanSaS
    Wurth makes some stuff I will be using. ABS Quiet and some CU800 should do the trick ** when I replace my pads with some Hawk's on the fronts I will be using this stuff to quiet my brakes down. Wurth is OEM supplier to German auto companies so the stuff is awesome ** just some cheap ass German auto dealerships here do not use their stuff. LOL
    Mar 15 2009
    CO
    yea what I have is exactly what you are describing TKKEN01. It is a metallic creak noise and yea it makes me feel like I'm driving a 10-15 year old car when I pull up to lights. Let me know what happens when you get it serviced if you go soon.
    Feb 08 2010
    2007 A4 2.0T
    Syracuse, NY
    Quote Originally Posted by bskis1080 View Post
    will do. in the meantime, i plan to try some brake cleaning junk from napa...
    Senior Member Two Rings jonjon88ss's Avatar
    Jan 04 2009
    88 Monte Carlo SS monster 86 honda spree gy6
    Woodstock, NY
    I have the same thing.....yet im too lazy to pull the wheel off and see whats up
    Bolt-ons and homemade go fast parts
    www.40sinabag.com
    IG: @Jonny_Greener
    Aug 18 2008
    Flerp
    Your pads are mostly gone, and the rails were the pads slide on are getting gunked up.
    You can alleviate it for a while by going to one of those high pressure self car washes and blowing the shit out of the calipers, but it will come back.
    If you want, take them apart, grease the rails/slides and the back of the pads and will go away, but while you are in the replace your rotors/pads as necessary.
    Veteran Member Three Rings Kevinskir's Avatar
    Feb 03 2010
    Portland Oregon USA
    I notice this too, and will be getting it checked tomorrow when I get my tire fixed (fucking found a nail in it today >.<) and Les Schwab is not open on Sundays.
    Veteran Member Three Rings Winners Eat Pho's Avatar
    May 17 2008
    I got it too, and noticed it right at the turn of the warm weather.
    Jan 27 2010
    Dayton, OH
    I got it too.
    May 11 2008
    Naples,FL
    same issue with only 33k on the ODO, just had all new fluid
    2.0 T Quattro - 20% tint,hardwired 9500i,alpine 757 amp,alpine 12" type r sub,RS4 Sway,Giac X-chip, VMR 19 710's wrapped in Conti Extreme DW, H&R Coilovers .
    Established Member Two Rings af1master692's Avatar
    Mar 20 2010
    Freehold
    same here it started creaking after a hard stop to avoid an accident. now it creaks like a wooden ship when i brake below 5 mph
    May 17 2007
    Long Island
    I have this "noise" too. On mine, it sounds like it's coming from only the front passenger side. It has always creaked (since new) whenever I was backing out of my driveway and I guess it wasn't that big of a deal to mention to the dealer, which I regret. Now it bothers me, with 25k miles. I feel it in the pedal a little bit too, as bskis1080 described.
    2008 A4 2.0TQ- Ocean Blue/Black 6MT
    2004 M3- Ti. Silver/Cinnamon 6MT
    Veteran Member Four Rings Coderedpl's Avatar
    Jul 27 2007
    Orange County, NY
    Holy crap you guys are awesome!!! I HAVE THIS SAME EXACT ISSUE!!!!! Sort of sounds like one of those old mattress springs right?
    Dealership was pretty useless in terms of fixing it under warranty. I went back there a few times and never got it fixed and now I'm sol and its driving me NUTS! They tried to tell me it could be my rotors because of a "lip" they have, but nope, thats not it because i just got brand new rotors and it's still there. What are we suppose to grease up on the calipers and stuff anyway? Maybe its one of the things that need to be greased up? I sprayed break clean on rotor and caliper and nothing :/
    Current: F80 M3 | 2018 Q7
    Past:2018 VW Golf R | 2014 S4 | 2016 Nardo Gray SQ5 | 2012 VW Golf R | 2006 Audi S4 | 2006 A4 2.0T |
    Feb 08 2010
    2007 A4 2.0T
    Syracuse, NY
    ya, that brake cleaning spray didn't do sh*t. although luckily the weather has gotten crappy and the creaking has subsided with the cold temps. i'm sure it will be back though...interesting what was said about the pads being almost shot. i'll have the dealer check them at the next service as well
    Jul 27 2007
    Orange County, NY
    I replaced my rotors and saw my pads are in pretty damn good condition. I was thinking of finding myself some s4 calipers or some shit lol
    Account Terminated Four Rings
    Oct 18 2008
    Delray Beach, FL
    Mine squeak when it's cold. Thank god I'm in florida now!
    Mar 15 2009
    CO
    Mine just lasted like a day or two and is now completely gone. I think it just had to do with the change in the weather and the car adjusting to the storage temperature change of like 50 degrees
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    Just noticed where all the creaking is coming from... NY and New Jersey LOL... I just heard my car squeal a little too... it must be from the change in seasons/temperature/humidity.
    Feb 08 2010
    2007 A4 2.0T
    Syracuse, NY
    Quick update on this: I brought the car in last Fri because the noise was driving me insane. It had become intolerable with the warm weather and I had to get it checked. They checked out the problem for me and did two things. First, they lubricated the caliper pistons to se if this would alleviate the problem. Also, all 4 pads were 90% worn, so I had the dealer replace them. Problem is gone. Check your brakes guys, the pads might be in need of replacement soon.
    Jul 27 2007
    Orange County, NY
    I think i might need the lubrication part rather than the pads. Mine are pretty good
    Apr 04 2008
    2006 Audi A4 Quattro
    South East Connecticut
    Quote Originally Posted by TKKEN01 View Post
    About 20k miles ago I had the creaking in my front breaks. I had the pads and rotors replaced (dealer had told me they were due before my next service). About 2 weeks ago my rear brakes started creaking. I had pads and rotors replaced on Friday. The pads and rotors were toast. As said above, definitely check your pad wear if you're getting the creaking noise (not the usual Audi brake squeal) because it could be a warning that your pads are on their way out.
    nick
    Jul 27 2007
    Orange County, NY
    Quote Originally Posted by 72mako View Post
    nick
    They have been like that for me for quite a few thousand miles.
    Apr 04 2008
    Quote Originally Posted by Coderedpl View Post
    Just a possibility, I did read that you had checked your pads and they were okay. I'm by no means an expert on brakes, just wanted to point out that the creaking I had coincided with needing new pads and rotors for both the fronts and the rears. Incidentally, I hadn't realized how bad my right rear inner pad was until heard the creaking switch to grinding as I ground down the rotor with metal to metal contact. Had to garage the car for a couple days and drive the truck while I waited for my parts to come in. That sucked, but it felt so good to be back in my car on Sat! :)
    nick
    Jul 27 2007
    Orange County, NY
    nick
    I know my rears need replacement very soon but the creaking is DEFINITELY coming from the front and it seems like it got worse for the summer.. It's driving me fucking NUTS!!!!!
    Apr 04 2008
    Believe me man, I know the feeling. It was awesome to get in the car Saturday morning and NOT hear the creaking! I felt like I was driving a hooptie last week!
    Jul 27 2007
    Orange County, NY
    Bump, anybody actually get this fixed other than replacing pads for example? Mine have quite a bit of life left and the problem seems to be getting worse ;(
    May 17 2011
    Northeaster PA
    I know, bad form to bring this back from the grave, but....
    If anyone googles this and brings it back up. You aren't crazy. No it's not pad squeal. It is a creak in the caliper itself, at a standstill. Greasing the pins made no change. My pads have plenty of life in them. I de rusted the carrier and still have it. I am going to have to pull it again and look for another surface that is rusting and maybe pull the piston itself to see what the rust is like under the boot. It is crazy annoying on hot days. It creaks so bad it set off the check engine light for both knock sensors exceeding the limit!!!!
    2006 A4 Avant
    replaced wrecked 04 A6 Avant
    replaced tired 98 A4 1.8tqm
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Quote Originally Posted by Spridle View Post
    If you pulled and lubed the guide pins and the problem persists, I would inspect the pistons next.
    It may be a good idea to pull the caliper and completely disassemble it, replace all of the rubber boots and seals, and re-grease the pistons (check for nicks!), and clean it all up along the way.
    That said, manufactured calipers are quite cheap and it may be more efficient (in both time, hassle, and money) to swap in a pair of fresh reman calipers.
    2019 SQ5 Prestige
    May 17 2011
    Northeaster PA
    It creaks with the guide pins and rattle clip removed! It seems to be something in the relationship of the caliper to the carrier. I can take a pry and rock the caliper up and down to the carrier and it creaks like hell. So I am guessing it is something to do with pad to piston contact, pad to caliper or caliper to carrier. The pop is crazy. You can feel it in the pedal. And I am not kidding it set the knock sensors off several times. Yet on humid days, it's basically quiet. Rainy days, not there at all.
    2006 A4 Avant
    Feb 15 2016
    Cambridge,Ontario
    brakes creaking
    Well the caliper to the carrier should be solid to the order of 60 ft lbs or so
    I would service he brakes will probably fix it
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Mar 14 2018
    SE PA
    I think the creak is from the front inner pads that have the piston retaining clips on them.....I think the creak comes from the inner bore of the piston sliding against this pad retaining clip
    Veteran Member Three Rings Flygman's Avatar
    Jan 27 2018
    Gothenburg
    Use proper grease on all metal-to-metal surface points.
    Current:
    A4 B7 DTM | BSR Stage 1 | CTS HFC | Simons catback | 034 HPFP internals | K&N panel filter | Garrett FMIC | DO88 intercooler piping & hoses | GFB DV+ | IE PCV Delete | Poly snub mount, rear wishbone & spindle bushings | B5 'lowering perches' | Judd T325 19x8.5 ET32 rear + ET35 front | Pirelli P-Zero 235/35R19 |
    Previous:
    RS4 B7 Avant
    A4 B7 Avant
    Oct 27 2015
    Phila
    I had this in my B8.
    I took the rear left wheel off and sanded down the hub face where the wheel is bolted to the hub surface.
    When I pulled the wheel off, a bunch of white dust fell off of the hub and I just ended up sanding the rest of the white dust/powder off.
    Put the wheel back on and pressing the brakes at low speed and the noise was gone. Not sure how the hubs and pressing the brakes have any correlation but it worked..
    2015 R8 | Suzuka Gray
    2015 Q5 | Monsoon Grey | P+ | Technology Package
    2009 A4 | Meteor Grey | P+ | Sports Package
