Originally Posted by
b4a6
lately my cars been running sluggish, sometimes chokes a little when i put it into gear...vac leak was my first thought so i replaced all the lines and today it went into limp mode and wont boost past 5psi
recent work: replaced fuel filter, installed tp, replaced vacuum lines
everythings stock except for exhaust system and tp
codes:
p0139
p0456
p0130
p0131
any help is greatly appreciated
THANKS
P0130 indicates a signal problem from your front O
2 sensor. Most likely with the heater circuit.
P0131 is also associated with the front O
2 sensor and indicates a low voltage signal.
P0139 indicates a slow response from your rear O
2 sensor.
P0456 indicates a small leak in the evaporative emissions system. Check out your N80 valve and make sure it isn't partially clogged with debris. Also check all the hoses to and from the N80 for leaks.
