Results 1 to 10 of 10
    Senior Member Three Rings lukeag25's Avatar
    Jul 02 2009
    B5 S4,V8 S-10, 12v CUMMINS
    Denver
    Question Re-coding with Vag com issues
    Did a Tip to 6sp swap. Everything worked out great but, I am having a hell of a time tring to get this thing to re-code! (It's an '02 AA box) I need to change the engine, ABS, and Cluster codes. I am using the shareware version (409.1 IIRC) with an e-bay cable. Everything checks out just fine, I think, communicates, pulls codes ect. The controllers just won't except the new codes! Engine:06711, ABS:04395, Instruments:02364. I used this same set up (on a different lap top) to code my old TCU so it should work. I tried to log in to the engine using Ross-Tech code 11463 (also tried 01283 and it kicked me out)and still no difference. I'm frusterated as all hell, so any insight would be greatly appreciated!
    Last edited by lukeag25; 03-24-2010 at 08:28 AM. Reason: COM don't know how that 'a' snuck in there. I HATE computers
    Stg3 B5 S4
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    I'm pretty sure there are certain controllers you cannot re-code with the Shareware version.
    Jul 02 2009
    Denver
    There are a bunch that one can't get into, deemed "slave modules".
    http://www.ross-tech.com/vag-com/vag-functions.html
    I am hoping that I screwed something up, but my gut tells me I need the full version.
    Stg3 B5 S4
    Jul 02 2009
    Denver
    Bump
    Stg3 B5 S4
    Veteran Member Three Rings Dubluv11's Avatar
    Jan 08 2010
    00 S4
    you'll probably need the full version...
    which one are you supposed to buy anyways? i am looking into getting it as well
    Jan 29 2007
    08 S4 00 S4
    MD
    When you try to do something that requires a full version, licensed interface, It should tell you that when you click
    'Do it!" using an unlicensed cable. Are you getting a pop up window that says this?
    08 S4- Stock SOLD
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by Dubluv11 View Post
    For the B5, all you need is a Key-USB. It won't work on some modules on newer, CAN based cars. There's an application chart on Ross-Tech's site.
    08 S4- Stock SOLD
    Jul 02 2009
    Denver
    Quote Originally Posted by mholme View Post
    Nope, that will pop up if I try to adapt, but not when I try to code. Lemi is working ok as well. Last night I tried re-loading 409.1 to my lap top and nothing changed.
    Stg3 B5 S4
    Established Member Two Rings Haterade's Avatar
    Sep 22 2009
    W204 C63, E60 M5, Sienna
    AC, Jersey
    i actually had the same issue with the full version of vagcom, would not let me recode cluster.
    Jul 02 2009
    Denver
    Bump, friend of mine helped me out and brought over a full version of Ross-Tech. No difference, still wouldn't take any codes. Thinking that the ECU is locked somehow from the flash/tune(which is unknown). Ideas? Seems like the easy way out is just swapping to an M box, but I would rather solve this issue!
    Stg3 B5 S4
