    Veteran Member Three Rings 07audi4's Avatar
    Dec 06 2006
    2007 audi a4 2.0T quattro
    rochester, new york
    tire sizing question
    Im looking to purchase some new tires for my staggered setup. The wheels I have are 19" x 8.5" in the front and 19" x 9.5" in the rear. Up front I am going to run a 225/35/19 and in the rear I was wondering if I could run a 245/35/19? Previously there was a 255/30/19 on the rear...but there isn't much of a selection in that size. Can anyone help me out?
    Chris
    also...would the size of the sidewall look the same? (255/30 compared to 245/35?) basically I am going a little narrower but want the sidewall to look about the same.
    2007 AWE Tuning Audi A4 2.0T Quattro
    APR Stock 91 93 Race / Evolution Motorsports Intake / AWE Tuning Front Mount Intercooler / AWE Tuning Downpipe Back Exhaust / Neuspeed Race Springs / H&R S4 Front And Rear Sway Bars / Fog Light Mod / 10% Tint With Custom Audi Emblems In Rear Windows
    Established Member Two Rings JD3's Avatar
    Dec 31 2008
    E92 M3
    Columbus OH
    best thing to do here is learn how to measure tire sizes yourself, believe me, it will make your life easier. Also, if you've got Quattro you better be careful, you don't want to run two different heights or circumfrances on your front and back. Think about it, they're rolling together. One wheel/tire setup can't be bigger than the other.
    Here's how to determine sidewall height.
    Let's use a tire sized 255/30/19. 255 is the width, in mm, of the tire. The 30 is what's called the aspect ratio. It's a percentage of the tire width and it determines the sidewall height. So you would take 255x.30 to determine the width of the sidewall in mm. In this case it's 76.5mm thick. 245/35 would be 245x.35 or 85.75mm thick. So 255/30 woudl be closer to your front tire height.
    Also remember that it's only one sidewall, so to figure out the overall height of your wheels and tires you would take the 19" for the wheel, and multiply the sidewall height by 2.
    Also, fyi, 25.4mm equals 1 inch.
    Senior Member Three Rings ADG05's Avatar
    Oct 17 2008
    Santa Monica CA
    This should answer your question:
    http://www.1010tires.com/tiresizecalculator.asp
    Veteran Member Four Rings audimeister's Avatar
    Jan 05 2006
    '07 A4 Avant S line Ti 6MT Quattro
    Oakland, CA
    If you have quattro, and must have the staggered look, use the same size tire front and rear. Different circumference tires on different axles will cause problems with your center differential sooner or later.
    Also, wider tires on the rear will cause the car to understeer even worse than stock.
    "Obsessed" is a word that the lazy use to describe the committed.
    Veteran Member Four Rings nramsey's Avatar
    Dec 09 2004
    Quote Originally Posted by audimeister View Post
    ^ this
    - Nathan
    http://www.flickr.com/photos/nramsey
    2008 A4 2.0T Quattro Avant - Dolphin Gray
    Eibach Pro-Kit - Koni FSD - Rotiform MIAs
