I just got my sub setup project finished, and im putting back together my car but i can't get the rear deck cover to fit back in all the way. The 4 long plastic tabs are going in just fine, but the sides were the cover connects to the pillar aren't fitting. There are holes in the deck cover that aren't lining up with the tabs on the pillar. It almost seems like the rear deck isn't in far enough, but that doesn't seem like the case (edit: i just took a look at it from the outside, and it looks like the deck isn't pushed in all the way....derp). Its 9:30pm, so i am spent and it can wait until tomorrow, I just wanted to know if any of you gurus have any advice/tips.
I will get pics up in a little bit. Thanks
EDIT: so nevermind? unless there is some sort of trick?
