Results 1 to 21 of 21
    Established Member Two Rings chirp's Avatar
    Dec 29 2008
    2008 Nissan Pathfinder 4X4 V8 LE
    ABQ
    Something moving when braking.
    Ok, i have a new issue that I hope I can explain well enough for someone to help me out.
    It happens anytime I brake, but can be felt most when rolling about 5 to 10 miles an hour and pushin the brakes. It feels as if something is shifting its weight forward.
    I just noticed this in the last week or so and I can't figure it out. If I let the car roll about 5 mph and give the brakes a quick stomp it feels like the engine slides foraward. (I know that sounds rediculous, just trying to decribe it)
    I have cheacked the engine and motor mounts and they look good. I just replaced all the front suspension linkage 4 months ago.
    I have done searches and read alot on the drivetrain play. I have that issue also. I think it is unrelated since I have had drivetrain play since i bought the car and the new problem has just started (or I just started noticeing it.
    Anyone else have this problem? Any ideas, suggestions.
    Thanks ahead,
    chirp
    Established Member Two Rings andyzzdae38's Avatar
    Jun 27 2009
    2007 Vulcan
    Marion IA
    Have you checked the front subframe bolts? I have read somewhere (can't remember where) that the bolts can come loose over time. Also check the whole subframe for cracks.
    -Andrew
    Current- 2004 Honda Accord EX 4cyl auto
    Old- 2005 A4 1.8TQ6M USP R.I.P. January 28, 2011
    Old- 1999 A4 2.8Q pre-facelift
    Now equipped with Vag-com and Bentley
    I can help you with Audi work
    Dec 29 2008
    ABQ
    I will look at the subframe bolts. I ahven't checked them. I didn't notice any cracks, but I am going to put it back in the air this weekend to check again.
    Appreciate the reply. I am looking for all ideas before I jack it back up.
    Established Member Two Rings rmv6's Avatar
    Aug 05 2009
    2001 Allroad
    Grand Rapids, MI
    have you checked all the bolts holding on the braking components?? maybe bushings in the control arms?
    Dec 29 2008
    ABQ
    I did check the brakes. I have Brembos and everything looks tight.
    Dec 06 2007
    Calgary, AB, Canada
    If you're sure all the brake components are tight, then it's probably a busing or maybe even a ball joint. I would start checking the CA and SF busings, and inspect the ball joints in the CA's.
    Senior Member Three Rings BlackS4TT(Josh)'s Avatar
    Jan 24 2006
    Ohio
    When you dropped the subframe to install the lower control arms... did you replace the rear subframe bolts (18mm hex head)? Or were they re-used?
    I re-used mine when i did my control arms, and I had to go back and replace them to eliminate the clunk under hard braking. They're a one-time use bolt, as they're designed to stretch when properly torqued.
    B7 S4 Avant
    Senior Member Three Rings hcaudikeed's Avatar
    May 25 2009
    2000 A6 2.7t 6sp
    Around
    Check the inner bushing of the front lower rear control arm. Mine makes the same noise and I narrowed it down to that. And don't think cause you just replaced them they're fine. I replaced mine about a month before the noise started.
    J-Fonz Tuned| F21's | CoolingMist Stage 2| Southbend Stage 3 Kevlar w/ RS4 PP| Fidanza LWFW | Bosch EV14 72# | DW300 Pump | SRM SMIC's | 034 Track Density Motor Mounts | 034 Street Density Trans & Rear Diff Mounts | 034 Bipipes | 034 85mm MAF Housing | 034 Snub Mount w/ Bracket | EFK | 710N's | Hartmann DTM 18x8.5 | 235/40/18 Cooper RS3-S's & 225/45/18 Dunlop Wintersport M3's | H&R Race Springs | Koni Yellow Sport Shocks | SSAC V-Band DP's | Milltek 2.5 inch Catback | S6 Doorblades |
    Dec 29 2008
    ABQ
    So I got underneath the car again this weekend and everything is tight.
    Today I stuck my head out of the window and while tapping the brakes I could see the left front wheel shifting forward about an inch. I called someone to come over and look underneath the car while I tapped the brakes while rolling forward. He told me that there was alot of movment at the lower control arm inner bushing. Much more than compared to the right side.
    Does this sound resonable to anyone? It seems right to me, but just wanted opinions before I start purchasing parts or fighting to have it covered under warranty.
    I bought the parts from blauparts and installed them in Oct. They tell me they have a one year warranty, but I need to purchase a new one and send the old one in to see if it can be covered under warranty.
    So now my options are to try and have it covered and take the chane of loosing $100 if they don't cover it after I purchase a new one, buy a new arm (possibly cheaper on fleabay or somewhere), or press a new bushing in.
    Any inputs would be appreciated.
    Thanks
    chirp
    Sep 27 2007
    00 S4 6sp, 06 Mazda3 HB Auto
    Columbia, SC
    You stuck someone under the car while moving?
    Wow man you got some mad persuasion skills ;)
    00 B5 S4 - K04, Stern Soft MM, Stern Snub, DTS, Neuspeed Rear Sway, Oinkies, GIAC stg 2 XR, Vogtland GT, SSAC copy. Soo... Stg 2.31456?
    06 Mazda3 - Wife's car and autox car
    96 Eclipse GSX - Gone
    03 Acura CL Type S - Gone
    96 Soarer GT - Gone
    93 RX7 R1 - Gone and missing her
    Dec 29 2008
    ABQ
    Yup.
    No Actually i had them lay beside and lookunder from the side.
    So is it likely for CA bushing to go bad in 6,000 miles?
    Dec 06 2007
    Calgary, AB, Canada
    You sure it's the CA bushing, and not the SF bushing?
    I would say it's totally abnormal for a CA bushing to go bad in 6,000 miles, even if the car is lowered.
    Dec 29 2008
    ABQ
    Dumb question, what is SF?
    Dec 06 2007
    Calgary, AB, Canada
    Sub-frame.
    Dec 29 2008
    ABQ
    I don't think it is the subframe. When the brakes are applied the wheel moves forward and tweak the suspension. If the subfram was moving, I would think the suspension would not tweak, it would all move together. Something is bad and allowing the wheel to push forward.
    Almost as if the brak on that side was not working and all the other were. That doesn't seem to be the case though as the brakes work and it doesn't pull.
    Dec 06 2007
    Calgary, AB, Canada
    The suspension would still move, since the bottom would move, but the top wouldn't.
    Dec 29 2008
    ABQ
    Looks like I found the problem. Front left wheel. Lower rear control arm, inner bushing has a plastic insert that is cracked into 2 pieces on both sides.
    Can these bushings be baought without buyimg the whole arm.
    There is suppossedly a 1 year warranty through blauparts, but I can't find my paperwork, imagine that. I sent them an email and hopefully they will replace it, but now counting on it.
    Dec 29 2008
    ABQ
    So now that I am pondering this situation more, does that plastic piece really keep the bushing that much stiffer?
    When I removed this arm, i moved the other control arms around and they all had some normal looking play in them. It is hard to believe that ...
    1. The bushings in all ht econtrol arms are what keeps the wheel and suspension from traveling forward and aft
    2. These only have 6000 miles one them and are do not look to be as stiff as they should be.
    So is the broke plastic piece letting my wheel moved forward and aft, or is wahtever that is letting my wheel move broke the plastic piece?
    The subframe bushings look tight. I see no movment in the subframe whatsoever.
    Still looking for any input.
    The are Ocap brand by the way from blauparts. I do not think I would buy this brand again although their write up makes it seem that these are top quality.
    Again thanks.
    Jan 29 2007
    08 S4 00 S4
    MD
    You sure that's not some sort of shipping insert that's supposed to be removed before installing? I've not seen that on installed control arms. It isn't molded to the rubber, is it?
    08 S4- Stock SOLD
    Dec 29 2008
    ABQ
    No it's not molded, but it is pressed in pretty good so I don't think it was for shipping purposes. Looking at pictures of different brands, some have it some don't.
    May 25 2009
    2000 A6 2.7t 6sp
    Around
    i mentioned it would be the inner bushing but now i believe it has more to do with the rear subframe bolts. it started with the right side, but when doing my suspension swap, i lower the subframe a bit on the left side and i now have a clunking on the left side as well. i will order the subframe bolts and replace those as a start. if not, ill get the inner bushing and press it in. let me guess, you bought the ocap control arms?
