Results 1 to 7 of 7
    Jan 15 2010
    Santa Barbara, CA
    Removing swirls from piano black trim
    I'm sure this has been discussed before, but couldn't find anything by searching. Does anyone have any tricks for removing light scratches/swirls from piano black trim, without removing the trim from the car?
    It seems like using a swirl remover (glaze) by hand and masking off the vinyl would work well. Something like this: http://www.properautocare.com/3mperswirmar.html
    Veteran Member Four Rings 'mk4-turbo's Avatar
    Oct 02 2007
    Montreal
    i would say doing it by hand is your best option, like you said just tape the edges and apply a swirl remover and buff it out with a MF cloth
    Jan 15 2010
    Santa Barbara, CA
    Can anyone recommend a particular swirl remover that might work well (something with lots of fillers, not abrasives).
    Oct 02 2007
    Montreal
    i wouldn't know cause there is such a variety
    but here you cand find a variety
    http://www.detailersdomain.com/index.aspx
    Veteran Member Four Rings hoppy6698's Avatar
    Sep 10 2009
    2015 BMW M235i
    Yorktown, VA
    I fixed mine about a week ago now. Used PC with CG All-in-one polish. Went over it real quick, very light pressure - came out good as new.
    Warning - it is plastic, so you don't want to go too aggressive. AIO polishes and something like Menz PO85RD would be a start. Take a look here: http://www.audizine.com/forum/showth...h-Chart-Update
    "A man who won´t die for something is not fit to live." - MLK Jr.
    Jan 15 2010
    Santa Barbara, CA
    Seems like this might be a good option: http://www.detailersdomain.com/menze...azepo115c.aspx
    Veteran Member Four Rings jareds941's Avatar
    Jan 12 2010
    Jackson, WY
    Any before after/pics?
    Mine: 2021 Ford F150 PowerBoost
    Hers: 2016 Daytona Gray SQ5
    Previous:
    2004 E46 M3 Track Car
    2019 Daytona Gray S4
    2014 Glacier White S4
    2014 Glacier White SQ5
    2008 Daytona Gray RS4
