Results 1 to 6 of 6
    Feb 22 2010
    1961 Lincoln Continental
    Lake Mary, Florida
    got underneath the car
    So I got underneath the car and found some interesting information.
    I thought that the oil underneath the car was from a main seal, but the fluid appears like it could be transmission fluid, and also seems to be coming from in front of where the engine and transmission meet and possibly above those lines that have the transmission fluid on them, at about the same time the transmission has been slipping...is there a source for transmission fluid from in front and above where the engine meet and those lines are in front of that cross-member?
    Couldn't find much in the forums on this.
    Jan 29 2007
    08 S4 00 S4
    MD
    This is why you should never look under your car...the less you know, the better
    Is this a tip transmission?
    08 S4- Stock SOLD
    Dec 06 2007
    Calgary, AB, Canada
    Trans cooler lines.
    Feb 22 2010
    Lake Mary, Florida
    Yes it is a tip.
    Quote Originally Posted by The_Jerbel View Post
    Trans cooler lines.
    Does this happen often? Thanks!
    Dec 06 2007
    Calgary, AB, Canada
    Has the motor or trans been pulled recently?
    I wouldn't say that the lines are a common problem, but if you pinch them while installing the motor/trans, or bing them up against the chassis, you could cause a pin hole or a leaky seal.
    Feb 22 2010
    Lake Mary, Florida
    Actually yes. I just had it out for maintenance! Wonder how much they are to replace...
