Results 1 to 32 of 32
    Mar 04 2010
    Des Plaines/IL/Midwest
    S4 door blade questions.....
    Hey guys, for those of you that have purchased the S4 door blades did they come in gray or black? Hard to tell from some of the pictures of the retailers selling them. ECS says that they are black, my car is brilliant black (it doesn't have the plastic lowers luckily) would they match or do i need to get them painted to match? If i need to get them painted can i do them myself or just take them to a shop? Thank you.
    05 A4 1.8T/GTRS/REVO Stage 3/550CC Injectors/034 Manifold/ER Competition FMIC/Magnaflow Catback/Carbonio CAI/Forge 007 DV/034 HFC/NGK Copper/RS4 Sway Bar/VMR V708/KWV1 Coilovers/Pioneer AVICZ1/ JL W7 Sub/Amp
    Veteran Member Four Rings ApexIt's Avatar
    May 28 2008
    2005 A4
    You would need to get them painted to match. They closely match the stock unpainted lowers of an A4 iirc. Painting is a pita if you dont know what youre doing so I would suggest getting the professionally painted.
    RS4 Rear Sway :: KW V1 Coilovers :: B5S4 Calipers :: W&L Catalytic Converter :: 30% black tint :: S4 Door Blades
    Active Member Two Rings MOBBER's Avatar
    Mar 01 2010
    04 A4 1.8T / 02 ESCALADE
    Compton, CA
    Are those blades hard to install?
    Veteran Member Four Rings Rommulus's Avatar
    Aug 29 2007
    '03 1.8TQM
    Portland, OR
    They come matching the gray unpainted lower color. Exact match. Personally, I think that gray doorblades look good with painted black lowers. It's a nice contrast! Check it out!
    http://www.audizine.com/forum/showth...atured+Az%27er
    Aug 29 2007
    '03 1.8TQM
    Portland, OR
    Quote Originally Posted by MOBBER View Post
    They are just about the easiest thing to install. If you can operate a screwdriver you will have no problem.
    Registered User Four Rings greg@podi.ca's Avatar
    Jun 21 2008
    Quote Originally Posted by Rommulus View Post
    Just remove two little screws, slide the blades over an inch and they'll fall right off
    Dec 09 2008
    Wisconsin
    Anyone getting light rust under their doorblades? After a period of non-washing due to the frigid weather I started seeing some orange colored runoff around the edges. I popped one off tonight to find some rusty colored areas. Just curious if this is highly abnormal or not...
    Veteran Member Three Rings dsq's Avatar
    Aug 10 2007
    B6 1.8TQM
    toronto
    i had rust on my 6 year old flat blades when i took them off to put my s4 blades on. not sure about my s4 blades now, it's been about 2 years.
    | bbs | vogtland | giac | racetec | alcon | and more |
    in the rare event of an erection lasting more than 4 hours, seek immediate medical help to avoid long-term injury.
    Dec 09 2008
    Wisconsin
    Was it the blade itself that was rusting, or the door? I'm actually talking about flat blades and didn't have the time or daylight to give everything a good wash and inspection. Probably won't all week.... (I can't wait for summer sun to get here)
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    The blade itself CAN"T rust its made of a plastic-composite material.
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Veteran Member Four Rings a4darkness's Avatar
    Dec 01 2007
    San Jose CA
    The S4 blades used to be shipped color matched to what we commonly refer to as 'unpainted lowers' as seen below on Tgr_Clw's A4. Buy em and they come matched to your non-body paint matched / "unpainted" lowers.
    As of very recently, it was discovered that S4 blades are now being shipped in the same lighter gray color as the USP lower front as seen below on Skidmrk's A4. Notice the lowers and front do not match. This is the ballpark color of S4 blades now.
    [Yes he has a unique style, we all know this. Let it go.]
    Mike Hood brought this to our attention in the B6 forum on QW:
    http://forums.quattroworld.com/a4b6/msgs/19783.phtml
    So then OP, since you have an 05 with lowers that are factory painted to match your car, you'll need to have these blades painted to match your vehicle. Additionally, unless whomever you're ordering from has old stock left over, they won't come in the black color as seen on Tgr_Clw's A4 above nor the A4 linked by Rommulus.
    On a side note, as I do have UPL, if I ever decide to get S4 blades I'll now have to paint them, even though my lowers are 'unpainted' so to speak. Failboat.
    Active Member Two Rings clm6113's Avatar
    Sep 03 2009
    GSX-R 1000
    Manama, Bahrain
    Just got my door blades from ECS. Three matched my unpainted lowers, one was white. Painted to match following a thread on this site (http://www.audizine.com/forum/showthread.php?t=306941) - a perfect match.
    Chris
    '02 A4 1.8TQ : Stage 2+ : 034 HFC : APR cat back exhaust : AWE FMIC
    May 28 2008
    2005 A4
    Quote Originally Posted by SpacemanSpiff View Post
    I actually noticed little orange/yellowish spots on some of the blades myself. You cant see them unless your face is right up to the blades fortunately. I am beginning to wonder what they are.
    Veteran Member Three Rings Prospect25's Avatar
    Jan 09 2010
    LoHi, CO
    The rust is from the screws that hold the blades in place. If you wash off the
    area where he blade goes and can visually observe rust then it may be on your door panel. But I
    have yet to hear of anyone with rust problems on their car
    Veteran Member Three Rings FoRbAnNa's Avatar
    Jan 02 2010
    2006 A4 B7 DTM 2.0T Quattro
    Norway
    Quote Originally Posted by Prospect25 View Post
    Until now. I have a rust problem under all four doorblades Its like just under the doorblade and in the two screwholes for the blades. Didn't notice it after a year or so after I've bought the car when I took the doorblades off. Arrg! So now I'm saving up for a full repaint of the car since there is rust on all doors, stonechips on the rear fenders and I had my Rieger and Hofele bodykit installed. Saying audis don't rust is like eating yellow snow, your in for a big surprise
    And btw, two of my S4 doorblades came already primed in a light grey color while the other two blades came in the dark grey/"black" aka unpainted lowers color. Bought them from a shop here in Norway.
    Veteran Member Four Rings 3vom's Avatar
    Aug 26 2009
    Quote Originally Posted by a4darkness View Post
    Dear god, that thing is so fucking ugly.
    I love boost.
    Veteran Member Four Rings Peacob's Avatar
    Jul 08 2009
    Bicycles
    Detroit MI
    Quote Originally Posted by 3vom View Post
    Its not that bad... just the rims and the eyelids are the things killing it IMO
    -Brian
    B6 A4 USP OEM+
    B8.5 SQ5
    B8 A4 Avant S-Line Prestige
    Aug 26 2009
    Quote Originally Posted by Peacob View Post
    And the grill and two tone.
    I love boost.
    Dec 01 2007
    San Jose CA
    You wouldn't happen to have a pic of the 'white' blade would you?
    Quote Originally Posted by clm6113 View Post
    Just got my door blades from ECS. Three matched my unpainted lowers, one was white.[/IMG]
    Dec 01 2007
    San Jose CA
    Find me another pic of an A4 w/an unpainted / from the factory USP lower installed. ;-]
    Account Terminated Four Rings
    Feb 12 2009
    03 Audi A4 1.8T
    East Coast
    what about on DTH
    Jan 02 2010
    Norway
    Did the white doorblade match the light grey doorblade I have? The light grey in the pic was already primed from the factory when I bought them while the one on the left was in the standard "unpainted lowers" color and finish.
    Dec 01 2007
    San Jose CA
    Thanks for posting a pic, I do appreciate it. Saving that one.
    Looks like AoA is shaving down costs where they can by no longer shipping these from the factory to match the UPL of our 03's and earlier.
    Oct 02 2006
    Wadsworth,OH
    Due to dwindling supplies S4 door blades are getting imported as "unpainted lowers" or in a light grey primer. There is no rhyme or reason to it, other than supply/demand equations. We currently have S4 door blades for 36% off and have worked very hard to keep prices this low as it is nearly impossible to find a supply of these anymore. If you are interested, click here.
    Dec 01 2007
    San Jose CA
    Dwindling supplies? Nearly impossible to find a supply of these? Come on Chris. There has never been a shortage of S4 blades. Maybe around tax return season or Christmas. We're weak willed like that. ;-] But considering the going rate for these, the ECS price is quite good. Although PureMS still has ya beat.
    Audi is being smart here. The vehicle these were intended for (B6 S4) comes completely body painted from the factory. So then, it's an obvious business decision as to why they're no longer spending the extra money to add an another coat of paint in addition to this light gray primer. Bean counters are hard at work, and they made the right call here.
    Funny thou, after seeing Jorge's beautiful Avant yesterday, I'm starting to sway towards no blades.
    http://www.audizine.com/forum/showth...a4-white-dream
    Then again, once the White USP Avant fever wears off I'll likely come to my senses.
    Quote Originally Posted by Chris@ECSTuning View Post
    Oct 02 2006
    Wadsworth,OH
    You are wrong and right. I need to re-phrase - it is getting nearly impossible to find these at this price, which is why we are subjected to mismatched primers. The average dealer in the US is charging ~700 for these and I think it may have gone up to ~800 last month.
    Also, PureEMS does not offer free shipping on their blades, so they are not the better option if you live in the continental US ;)
    Feb 12 2009
    03 Audi A4 1.8T
    East Coast
    True.... but its also on back order ..... i have a source that i can get them for cheap but they are veery limited
    Dec 01 2007
    San Jose CA
    I sure hope no one is still sourcing parts like S4 blades from a dealer. No shocker on that pricing thou. But that's why we have ECS, right? So we don't have to support our local Stealership. lol
    Fair enough, fair enough. The important thing is that they're still available.
    Frankly, I'm not so much interested in the nickles and dimes but what the part will be when delivered. EX: Some time ago, hunted around endlessly for a clear answer concerning the actual color of an USP lower, hence why I have that pic above saved (and now the primer gray blade shot as well).
    And good to know about the shipping, I tip my hat. But for Short-Attention-Span-Theater guys like me, you're gonna need a flashier icon. I glanced right past this:
    Free Shipping
    Maybe one with boobs. That usually does it.
    Oct 02 2006
    Wadsworth,OH
    @a4darkness - I passed the recommendation onto our graphic designer, we'll see what he comes up with.
    @secnd2no1 - not back ordered, special order, they should land in 9 days :)
    Feb 12 2009
    03 Audi A4 1.8T
    East Coast
    ah gotcha.....
    Dec 01 2007
    San Jose CA
    ROTFL
    Well played.
    Sep 03 2009
    GSX-R 1000
    Manama, Bahrain
    Sorry. Should have snapped a few pics of the mis-colored blade before I painted it.
    Chris
