Results 1 to 28 of 28
    Veteran Member Four Rings Hansel's Avatar
    Apr 27 2009
    Chicago
    corner balancing?!?!?
    What's the point of it? I just spent another $150.00 on it.
    Apr 27 2009
    Chicago
    Thanks buddy
    Apr 27 2009
    Chicago
    So for a everyday car...this is something I should not do???
    Dec 24 2009
    blackberry
    Quote Originally Posted by Hansel View Post
    yes, go for it. I got my kw variant 2's installed, then 2 weeks later i got it corner weighted. Make sure you let the suspension settle a little before you get it corner weighted. Its no good to install the coilovers, then get the corner weight done immediately
    Apr 27 2009
    Chicago
    Quote Originally Posted by champion View Post
    Gotcha. He wants to do it now before the alignment.
    Dec 24 2009
    blackberry
    i got my alignment done the same time as the corner weight. Im not sure if he did the alignment first or the corner weighting. Most likely the alignment. It probably doesnt matter which one is done first though
    Apr 27 2009
    Chicago
    Does it make a big difference?
    Dec 24 2009
    blackberry
    does what make a big difference?
    Apr 27 2009
    Chicago
    the corner balancing.
    Mar 11 2008
    B7RS4 & e46Ms
    If you corner balance...do it in this order: install suspension > 1-2weeks to settle springs > corner balance > alignment.
    FRRG AZ Ring
    Dec 24 2009
    blackberry
    X2
    Apr 27 2009
    Chicago
    why would the shop do it all in one day?
    Dec 24 2009
    blackberry
    they shouldnt do it all in one day. the suspension needs time to settle in before the corner weighting should be done
    Apr 27 2009
    Chicago
    They warranty all their work...so should I drive it for a while then take it back?
    Mar 11 2008
    B7RS4 & e46Ms
    nothing's going to break by them doing it all at once... think of it this way... once your suspension settles, your corner balancing goes away...and your alignment now becomes out of line as well...causing uneven tire wear. That's a tough case to fight them on, and instead of replacing your worn tires, they'll probably just give you another alignment...tires are more expensive.
    If you're already stuck with them doing the install/corner balance/alignment in one day. Do this: ask for a full printout of the alignment specs (height, weight, toe, & camber settings for all four corners). Wait two weeks, and check your height on your own...if it's lower (it will be), go back to them and say your suspension settled, and now your corner balancing & alignment is off. If you're lucky, they'll put it back on the rack and reset everything for you. If they're going to be d*cks, they'll put it on the rack out of courtesy, then tell you the alignment is "within spec" and the height change has had a minimal impact on the corner-weighting.
    This is why I give EXACT alignment specs... So there's no grey area. They know exactly what they are required to deliver.
    If they haven't started corner-balancing & alignment yet, tell em you want the susp to settle for a week or two, then you'll take it back for that part.
    FRRG AZ Ring
    Dec 24 2009
    blackberry
    couldnt have said it better. But really OP, listen to this guys advise and do what he says because the corner weight and alignment will be off within 1-2 weeks
    Apr 27 2009
    Chicago
    I'm calling them now......Thanks bro
    Dec 24 2009
    blackberry
    good luck.
    Jun 30 2009
    T.O.
    Make sure when you get the corner weight done, you are either sitting in the drivers seat or they have replaced you with something of equal or similar weight.
    Without this, when you get in the car to drive it, the specs will be off as more weight will now be on the drivers side.
    Apr 27 2009
    Chicago
    No he asked what I weighed and I told him...
    Mar 11 2008
    B7RS4 & e46Ms
    Quote Originally Posted by spoonfed View Post
    excellent addition...I have them do this everytime I get an alignment done.
    FRRG AZ Ring
    Veteran Member Three Rings rzundel's Avatar
    Sep 20 2008
    Ferrari Challenge Stradale, Maserati GranTurismo S, Range Rover HSE, Porsche Panamera
    Westlake Village, CA
    Unless you plan to track the car I think corner balancing is pointless. I had mine done and frankly, it's hard to tell the difference. Besides, I wasn't real excited having every corner sit at a different ride height and to get it right your rear will sit lower than your front. I took mine in when I had my ride height readjusted and passed on the corner balance. No real difference noticed as a daily driver. Save your money.
    2005 Audi B6 Tip
    HRE M40 20x8.5 et34, HANKOOK Ventus V12 235/30/20, BREMBO 6pot Front BBK, BREMBO 4pot Rear BBK, KW VARIANT 3 Coilovers, LABREE Res Cat Back w/4" tips, GIAC ECU Flash, AE Corner Balance + Alignment, HOTCHKIS RS4 H-Sport F&R Anti Roll Bars, STERN Adjustable Control Arms, AE PERFORMANCE Black Optic Hood and Bumper Grilles, Clear Corner mod + Silver bulbs, Rear Valence Painted Satin Black, 30% Window Tint, Front Clear Bra, RS4 Pedals.
    Veteran Member Four Rings LJH's Avatar
    Oct 03 2006
    '84 Ur-q, '04 S4 6MT, '08 Outback XT 5MT
    When I did the C/O's in my B5 S4 I was wondering the same thing. I had a very respected motorsports shop do my alignment and I asked about corner balancing. They asked what I do with the car and told them that I might do 6-8 Auto-X's, and do not plan on doing a full on campaign like I did when I was younger, as well as 1 or 2 HPDE's they said that corner balancing was a complete waist of money.....
    Cheers,
    Jim
    Mar 27 2005
    The Cold North
    I completly aggree, but.
    Honestly without the addition of adjustable sway links there we don't reap the full benefit of a full corner balance (unfortunatly our sway bars add some preload to each corner). You could cross weight the car if you want.
    But just get a quality alignment to your specs with you in the driverseat and call it a day.
    If you find some adjustable sway links please let me know. I have been trying to find a set and after talking with JetJockey about it he was also unable to find any either
    I just let my suspension settle for 2 weeks and heading in for an alignment on thursday. Luckily everything settled even (~1/8").
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Mar 11 2008
    B7RS4 & e46Ms
    Quote Originally Posted by EBG 18T View Post
    We can't get these yet?: http://sternproducts.com/blog.php/
    FRRG AZ Ring
    Veteran Member Three Rings Whatset's Avatar
    Dec 02 2008
    Jeep & a Vespa
    Left of center
    ^^Have not seen them for sale just yet. I am actively watching for them.
    Mar 27 2005
    The Cold North
    Last time i asked Mike Kim about them he had no real ETA.
    2020 Chevy AEV ZR2
