Results 1 to 7 of 7
    Veteran Member Four Rings topquarkpc's Avatar
    Aug 03 2009
    PNW
    Question boost question searched but not getting the answer i need...
    so i installed the awe vent boost gauge over the weekend and noticed that the boost isn't holding like my other car (TDI) does.
    i have stage 2+ (TIP tranny with GIAC pump and Piggies & vibrant cat-back)
    when i push it hard the boost will peak out at about 15 psi and then it will not settle anywhere during cruising (after hard accel to cruise)...instead it will just go down to near 0 or go into vacuum at 60 - 70 mph...
    on the contrary, my TDI PD will hold the steady boost while cruising at 60 - 70 mph. at 13 - 15 psi...
    is this normal?
    i checked all the lines and it check out fine...no kinks or anything...
    could it be the breather filter in between the boost source tapping point and the gauge boost sender unit?
    help?
    Active Member Four Rings CrtchRktRcr's Avatar
    Feb 25 2009
    CRF50
    Scottsdale AZ
    If you're not on the gas then it won't boost. If you're just holding a steady speed you shouldn't be boosting.
    AEB B5 A4, QUATTRO MANUAL SPORT-H&R,FORGE,1BAR,5BAR,BOOM
    xbox live: Cr0tchf4i
    ["im in the computer lab and some dude with about 8" just sat down next to me -S4Jet"
    WWW.ASKMY2CENTS.COM
    Veteran Member Four Rings KNaudi's Avatar
    Jan 11 2009
    B5 S4, C6 S6
    Chicago and IN
    cruising you should be in vac. what's the problem? I have to admit that the original post is a bit hard to follow.
    My WTB List:
    -Sport (all black) shift surround for 6MT
    -Sport (all black) ash tray cover
    KNaudi's story
    May 04 2004
    00 BB S4
    York, Pa
    Horrible post, but it sounds normal...
    00 S4 BB Stg3
    Stolen Tune|K&N|STACK|DAR|KW V1|VAST - MBC |JHM SS Knob - SS lines - FMIC - Shifter - Trans Rebuild - 2pcs Rotors|AWE DTS - Boost Guage - DPs |BW K04|Southbend Stg 3|ASP Cat Back|V1|034 Snub - Race Tranny mount - Street Motor Mounts - Intake Hose - DVs|HAWK HPS|APIKOL RDM|H Sport RSB|6000k HID|Mille 12"|Hifonics|Focal|WOTBOX|AVIC910
    Aug 03 2009
    PNW
    well...i guess i wasn't very clear on the OP but basically what i was asking is whether S4 will show the chargers under load(boost) while cruising...
    i think i can deduce from what you all have posted above that it is normal. i've read things where folks here described and that sounded like i should've been under load (boost) while cruising.
    May 04 2004
    00 BB S4
    York, Pa
    Under load when you put your right foot down. If your engine was in boost at all time crusing, youd get 8mpg and alot of broken parts. With cruise control on, I see normally 10hg under cruise.
    00 S4 BB Stg3
    Aug 03 2009
    PNW
    So that's 10 hg in vacuum...right?
    I think that's about what I see on a normal flat road cruising.
