Results 1 to 4 of 4
    Jan 31 2010
    Fort Atkinson wi
    Need help with a few issues!
    Hi everyone i just bought a 2001 audi a6 2.7t a few days ago and i was wondering a few things about some random things
    -dome light and floor lights only come on when certain doors are open.
    -e-brake trim came off and was wondering how to re-attach it.
    -windshield washer jet set way to high doesn't even hit windshield.
    -heater fan squeaks when fan speed is low.
    -rear left window doesn't roll down i think its the window motor but are there any other common problems.
    -I need the part numbers for the lower middle front bumper grille and for the button that goes in the headrest to adjust it up and down.
    Veteran Member Four Rings audifirst's Avatar
    Feb 08 2005
    C5 A6 Avant, VW Golf TDI
    Ontario, Canada
    Answers
    1: Most likely switch in door is either broken or needs cleaning, to get that you need to remove the door trim
    2: look at the e-brake and the bottom of the handle should be a clip if it is broken then you need to buy new one, or if you don't want to spend money, just use silicone
    3: you can use a sewing needle to point the washer at the right direction, just put needle into nozzle and adjust to right direction
    4: most likely is it dirty, bearings tend to go , but you can remove the fan , and clean from dust that collects around bearing, with pressure air gun, there are instructions possibly here how to do the procedure cleaning
    5: it could be a window regulator or loose contact, does the other work ? if it doesn't work either there is a lock switch for rear windows could be broken
    6: here http://www.audiwholesaleparts.com/pa...layCatalogid=0
    check which you need and order one
    Difference in Audi B5 A4 Clusters Click Here
    Difference in Audi C5 A6 Clusters Click Here
    Replace ABS module in A6 Click Here
    DIY-Rear-Differential-Seal-replacement in A6 Click Here
    Jan 31 2010
    Fort Atkinson wi
    thank you so much for the help ill check this all out.
    Feb 08 2005
    Ontario, Canada
    For point # 4 the fan squeaking issue DIY fix Click Here
