Results 1 to 6 of 6
    Active Member One Ring mikefaudi's Avatar
    Dec 11 2008
    '04 A4 1.8T
    Lone Tree, CO
    Red hot exhaust manifold? Please Help!!!
    So I was on my home tonight and I was driving a little more aggressive than normal but nothing extreme. When I climbed out of the car there was a little bit of smoke coming out of the back of hood, I popped her open and the exhaust manifold is glowing bright red! pretty sure that's not normal. does anyone have any ideas what it could be? Thanks
    Veteran Member Four Rings mrbacardi35's Avatar
    Sep 18 2006
    Fresno/Los Angeles, CA
    Glowing red for the exhaust manifold is actually normal if you drive the car aggressive, but the smoke is something you would need to investigate which I think is also normal due to the way it was driven.
    Dec 11 2008
    '04 A4 1.8T
    Lone Tree, CO
    cool thanks I started to freak out for a minute.
    Veteran Member Four Rings forevraudi's Avatar
    Sep 01 2008
    San Diego, CA
    always let the car run idle before you park it to cool it down. If the E.M. was red, than so was your turbo => bad for the turbo to put the car away like that. That is what turbo timers are for.
    Apr 05 2009
    1984 Audi 4000S Quattro, 1989 Toyota MR2 SC, 1960 Alfa Spider
    SF BayArea
    my manifold was getting pretty hot after I had the Revo stage 2 flash and before I put the high flow cat in. Now its not as bad. Is your car stock?
    Veteran Member Four Rings MMMB00ST_A4's Avatar
    Mar 31 2009
    NC
    My car did that once, motor locked up the next morning...
    -Brandon
    APR | Oettinger | KW | iForged | Evolution Racewerks | Labree | Carbinio
    12.9@104mph
