Results 1 to 13 of 13
    Veteran Member Three Rings V8weight's Avatar
    Nov 16 2008
    Hudson, WI
    Sportec lower air vent mod
    I saw that the Sportec RS600 as well as their intercooler kit come with these lower engine shield vents. I figured I could replicate them for a lot less money, like $8.00. All it took was some 1"x1" angle aluminum, and some 3/16" rivets. First layout a pattern (I used 3/4" masking tape).
    Next cut out the openings (I used a pneumatic mini sawzall, but a keyhole saw would work), and then clean up your cuts with a file.
    Then cut the aluminum angle stock to fit the openings, mark your holes, drill, then rivet them in place.
    I also wanted to redo those rubber brake cooling dams that were scraped off of my lower shield, so I sacrificed an Impala front air dam that I found at work. It's a heavy plastic rather than the rubber that they were originally made of.
    And done.
    - Pat -
    2016 RS7
    -Previous-
    2013 S6 Prestige, 2010 A6 Prestige/Sport package, 2012 A4 Avant S/line, 1991 Coupe Quattro, E55 AMG, 2009 A4 Prestige, B5 S4 avant, B6 S4, C5 RS6, B6 S4 avant, 71 El Camino SS
    Aug 17 2009
    Pittsburgh
    VERY NICE! I love DIY homemade stuff like this. very innovative bro!
    Veteran Member Three Rings ccomengee86's Avatar
    Feb 17 2009
    '03 allroad 2.7T
    Dayton, OH
    Awesome! Great work.
    Maybe I should do that too. I can already feel the engine running hotter as the weather gets warmer.
    Apr 18 2007
    ny
    Nice job Pat. What is the overall benefit from this mod?
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    SOLD
    Greg
    C5UNION
    Nov 16 2008
    Hudson, WI
    Quote Originally Posted by A62TURBO View Post
    Well, it is part of the Sportec RS600 package, and honestly I don't know the extent of the benefits for this modification, but for $8.00 I figured I could afford to be wrong. The perceived benefits would in my simple mind be:
    Cool air being rushed over the entire engine and exiting through the rear of the engine compartment that hasn't already passed through the radiator. This should help to cool the turbo's off?
    Air coming through these vents would cause suction behind the radiator causing better airflow through the coolers.
    Here's a pic I found from Sportec's original RS600 promotional car.
    - Pat -
    2016 RS7
    -Previous-
    Feb 17 2009
    '03 allroad 2.7T
    Dayton, OH
    ^That is darn near identical. Please let us know if there's any improvement over the stock setup.
    Feb 24 2009
    san diego
    looks great!!! but with all the stuff that gets kicked up, i dont like that the belt is exposed right there... might be more practical for track use only??? but like i said, good job! it really does look great!
    Jan 07 2010
    PA
    Nice job!!! I'm also curious if you notice any benefit.
    Nov 16 2008
    Hudson, WI
    Quote Originally Posted by steve1912 View Post
    20 degree reduction in oil temps. I'm not worried about debris, this vent allows air to exit, not enter.
    - Pat -
    2016 RS7
    -Previous-
    Established Member Two Rings Mattynden's Avatar
    Aug 03 2009
    Culpeper, VA
    Great Mod this one off type of stuff that people do is awesome!!
    !Run what you brung not what you say you got!
    ~1967 Mustang Fastback 347 Stroker 5 Speed Conversion 4.30s in the rear trapping 11.60s in the quarter
    ~2000 A6 2.7t 6spd w/ gutted exhaust 18in rims
    Feb 17 2009
    '03 allroad 2.7T
    Dayton, OH
    Quote Originally Posted by V8weight View Post
    Wow, 20 degree drop in oil temp is quite significant.
    This will be my next mod. Any tips?
    Veteran Member Three Rings nrowensby's Avatar
    May 04 2008
    1999 Porsche Boxster
    Columbia, SC
    Very nicely done! Quite impressive how closely you replicated the original!
    ▄▀▄▀▄▀▄▀▄▀▄▀ B8.5 Squad ▄▀▄▀▄▀▄▀▄▀▄▀
    2014 Audi A4 - Stg2 - Monsoon Gray Metallic
    2015 Audi A4 - S-Line - Ibis White
    Jan 10 2010
    B6 Passat
    Nassau County
    look good
    Drive low, park lower
