    Veteran Member Four Rings KFizz's Avatar
    Dec 27 2009
    Edmonton/Alberta
    DMM HID Install problem
    Im in the middle of installing a DDM HID kit. For some reason the right headlight isn't working. I've tried putting the bulb in the other ballast and it works and i've tried using the ballast on the other side and it works fine aswell. so bulbs and ballast are both working. they just dont want to turn on. could this be a ground problem on the right harness? all other lights in the housing are working fine.
    Help me please.
    Kyle
    2014 a4 Allroad /// Ibis, Unpainted Lowers (True AR)
    Senior Member Three Rings Barker29's Avatar
    Jan 19 2010
    2018 VW Atlas
    South Jersey
    Did you try switching the wires that hook to the headlight housing itself... there are two red wires that come out of the stock headlight housing that you have to hook into try switching the way you hooked them up
    Feb 08 2010
    westford , ma.
    I had to reverse the wires - black to red - scary but worked
    Veteran Member Four Rings audifirst's Avatar
    Feb 08 2005
    C5 A6 Avant, VW Golf TDI
    Ontario, Canada
    also hook up relay to those HID if they are aftermarket , if you don't you will find later ballast problems
    Difference in Audi B5 A4 Clusters Click Here
    Difference in Audi C5 A6 Clusters Click Here
    Replace ABS module in A6 Click Here
    DIY-Rear-Differential-Seal-replacement in A6 Click Here
    Dec 27 2009
    Edmonton/Alberta
    Thanks guys. I switched them and it works great. I never would have guessed that.
    Kyle
