Results 1 to 2 of 2
    Senior Member Two Rings MAS4K04's Avatar
    Dec 29 2009
    LTZ400, B5 Passat, 01 Silver S4, 01.5 Pearl White S4 that needs some love
    SW corner MA
    Power Steering fluid
    So today i noticed that my power steering fluid was super low and i al noticed that it was very whiteish and frothy. Is this normal? Also when the cars running should i see fluid flowing threw the resivor?
    Dec 06 2007
    Calgary, AB, Canada
    It's normal for that to happen if the fluid is really low. Top it up. You should also track down where it's leaking from. Check the PS pump and the steering rack areas. Also check the connections at the bottom of the fluid reservoir.
