Results 1 to 16 of 16
    Senior Member Two Rings CKS's Avatar
    Sep 28 2009
    Truckee, CA
    I can't get the car to recognize my new RNS-E w/Vag-Com
    I bought a RNS-E from Kuko on eBay and have installed it successfully. I have coded the DIS successfully, but when I try to access either 56-Radio, or 37-Navigation using a Vag-Com to code the specifics, I get a "channel not found error" (I can't remember exactly what it says, but it's something similar to that)
    Here's what I had OEM: B7 S4 Avant with Bose Symphony, BT and Sirius.
    Here's what I have now:
    • RNS-E (SW:550, HW: H73, Map:8P0919884-Q-NAR)
    • BT: works on DIS and MFSW, but RNS-E says "no phone installed"
    • Sirius: works on RNS-E
    • RVC: I can't access the RNS-E, so can't code it to Lambo mode, etc... thus it currently only works in TV mode
    I have no idea why I can't do this, and have spent many hours researching here and audiforums.us. Here are some hypothetical possible causes (but now I'm guessing):
    • Euro SW in a US car- do I need to reflash the RNS-E to get my car to recognize it?
    • My installer did NOT use the new wiring harness that kuko provided, instead claiming that the one already in the car with the OEM symphony mated perfectly, is this the problem?
    So far I've vag-com'd a few other things successfully:
    • Front signals/parking lights off unless activated with turn signal
    • Seatbelt chime off
    • RNS-E to DIS
    What am I missing? I'm sure it's something simple...!? Thanks in advance!
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    You had Symphony II+ then I would assume, with a mating quadlock connector? Symphony II+ is the only one with a connector that would match the RNS-e.
    If so, there are two wires you need to switch in the harness in your car to get it to communicate correctly. Very simple fix. Symphony II+ communicates via K-line, not CAN.
    There is a write up with pictures on euroaddiction.net. It will definitely solve your problem. http://www.euroaddiction.net/forum/showthread.php?t=581
    Veteran Member Four Rings BASARAB's Avatar
    Mar 01 2010
    Farmington Hills,Mi
    Is vag-com genuine or an Ebay version?
    Veteran Member Three Rings neverfollow-rs4's Avatar
    Apr 23 2008
    2018 Q7, 1988 YUGO GV
    Atlanta
    Quote Originally Posted by PNW Avant View Post
    I see you llike my write up . To the op, follow that thread and you'll be fine.
    2013 S4 6MT P+
    Nav, Drive Select, Napa seats, B&O.
    Veteran Member Four Rings Mark's Avatar
    1959 MGA 1600
    Chocolate Land, USA
    If you can't access 56 or 37 and you have a genuine Vag-Com then it sound like your K-line, CAN + or CAN - is not connected. If the RNS-E info comes up on your center DIS then I the CAN +/- lines are probably ok and it probably is the K line. The RNS-E reads/codes/scans through the K line and not the CAN bus. Also . . . I have heard of people having too many things on their single K line . . . you shouldn't have that problem though as I have more attached then you do and it works fine. Make sure you have the RIGHT K line attached as well . . . since you have a B7 S4 you might have two. I believe that Audi switched to dual K lines in some B6's and all B7/B8's . . . so a B6 A4 might not have a dual line but the B7 S4 should. I am not really sure about this so take that with a grain of salt. Really though, if it's the K line going to the stereo it should be K1 so this should be a mute point anyways. Just make sure it's on the correct RNS-E pin.
    Check the pins on the OEM harness and make they match up with the RNS-E pins. The pin layout of the RNS-E in on the top of the unit . . . or GIS (google image search) for one. You can find your OEM pin layout doing a search too.
    -Mark
    1987 5000 CS TQ 2.2T I5 - No more . . .
    2002 Denim Blue A4 1.8TQMS - RIP
    2005 Ebony Black Pearl allroad 2.7TQMT6
    Kinda stock . . . Tinted, H-Sport Sways, HP-2 Calipers, RNS-E, Bluetooth, and iPod/Sirius combined
    Got Vag-Com?
    Sep 28 2009
    Truckee, CA
    uuugh, what a nightmare (for a noob like me). I was at the stereo shop yesterday (and this is the last time I will ever go there) with these instructions, and we moved:
    • B5 to B7
    • C7 to B5
    I didn't have a Vag-Com with me, and I haven't checked it yet, so I have no idea if we did it right. I'll check it when I have time, which probably won't be until next week. Now that I'm home, I can compare the wiring diagram on top of my SII+ to see what else needs to be modified (if anything).
    We did screw something up though since now my BT volume (currently only controllable through my steering wheel) doesn't go high enough. I guess it's possible that based on moving the wires, this control is somehow connected through the RNS-E, and since the RNS-E has not been properly coded yet it isn't functioning correctly.
    I will:
    • Compare the 2 wiring diagrams to figure out what else is different
    • Code my RNS-E if possible
    • Report back
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    It could have the do with that fact that the Bose pin is now properly grounded and your RNS-e internal amp is no longer working. Not sure though.
    Then maybe if you code it for Bose you'll get some volume back.
    Sep 28 2009
    Truckee, CA
    But since I have aftermarket amps and speakers, I don't want to code it Bose do I? I want a flat signal...
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Im not sure about the aftermarket amp/ speaker set up, but I know all the bose pin does is disable the RNS-e internal amp when it is properly grounded. I don't know what they coding will do.
    Ask about that specific question on this forum http://audiforum.us/rns-e/ . they are experts on the RNS-e system there.
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    By the way, did the pin switching enable the RNS-e to see your phone??
    Active Member Four Rings 00s4slvr's Avatar
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    Rns-e has to be coded for telematics us and bluetooth in ordr to recognize the phone as well as telephone 77.
    Established Member Two Rings D'Angelo's Avatar
    Oct 13 2007
    San Mateo, CA
    Quote Originally Posted by neverfollow-rs4 View Post
    Sorry but is this write up still available? I just got an EU unit from kuko too and want to install it in my A3 but don't really know how to begin since local shops keep telling me there's no point if my car didn't come with factory nav. I had Concert II+ but then swapped it for a Pioneer F90BT. I have discs all ready to go and am having a tough time finding up to date info on audiforum.us and can't tell what "*******" is supposed to mean in the link mentioned above. TIA for any help!!
    2008 A3 2.0T FSI
    APR Stage 2, Fully Loaded ECU | Full Votex Body Kit + Exhaust Tips | S3 Intercooler | H&R Rear Sway| Front Filler Plate | Aluminum Mirror Caps | 18" Drag Wheels DR19 (w/OEM centercaps) | 20% Tint | Debadged Rear
    Member # 63 of Coalition of The OEM+ Audi Owners
    Oct 01 2010
    b7 a4 2.0T 6MT
    also ebay vagf com will communicate with the rns-e as thats what i used to code it :)
    Registered Member One Ring tase's Avatar
    Nov 15 2010
    Aiken Sc, US
    Quote Originally Posted by CKS View Post
    [LIST][*]Front signals/parking lights off unless activated with turn signal[*]Seatbelt chime off[*]RNS-E to DIS
    [/LIS
    I have exact same problem except my car is A4 B7 without Bose system, so what is the verdict? where is problem ?
    Mar 01 2010
    Farmington Hills,Mi
    Quote Originally Posted by D'Angelo View Post
    http://audiforum.us/rns-e/13298-diy-...-ii-rns-e.html U have to remove aftermarket harness from your Pioneer unit first, I hope your installer did not just cut the wires, but used a proper harness
    Nov 15 2010
    Aiken Sc, US
    Smile
    Quote Originally Posted by BASARAB View Post
    Tanks BASARAB for link is exact what I need to now
