Results 1 to 9 of 9
    Nov 17 2009
    2004 A4 3.0L Quattro; 1985 Buick Regal Grand National
    Winnipeg, MB.
    New clunking sound when going from reverse to drive...
    Welp, just noticed this today. I was backing out of my parking stall at work, pressed the brake pedal, slipped it into drive and feathered the gas to get me moving. Not a second after giving it a touch of throttle, I hear a clunk coming from the front end and can feel it in the gas pedal of all things. I verified this twice more, both under the same circumstances. Slowly backing out, put car in drive, roll forward a couple of feet and "clunk".
    Any thoughts? I'm not going to get a chance to worry about this a whole lot. If I stop and put it in park or neutral then back to drive it doesn't make any sounds at all. Sounds like there might be some slack somewhere? Thanks for any thoughts.
    ('04 3.0 TIP non-sport)
    Mike B. - 2004 A4 3.0L daily driver, 1985 Buick GN on blocks.
    Aug 17 2009
    Pittsburgh
    torque converter locking up hard. get the trans fluid flushed and replaced and new trans filter. that should clear it up. don't let it get any worse.
    Nov 17 2009
    Winnipeg, MB.
    Thanks for the info! Is this a common problem with this transmission? It's nearing 65,000 miles now so was going to do the trans filter/pan gasket/ATF when I did the timing set, guess the trans will come a little bit earlier.
    Does it really take 9 liters of 75w-90?
    Registered User Four Rings greg@podi.ca's Avatar
    Jun 21 2008
    I've been having the same issue for a while now...it probably is common.
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Quote Originally Posted by [email protected] View Post
    Well there are all kinds of other things that can cause a clunk:
    Steering rack
    Ctrl arms
    Sway bar links
    Brake pads
    Front sub-frame
    Drive-train mounts (snub/engine/tranny/center/rear diff)
    Mine is steering rack related cause I only have the clunk when turning and stepping on the gas.
    U didn't mention that u have a hesitation B4 the clunk which is what I would suspect with a tranny problem. In terms of mileage u are quite low. I have my girl friend change her tranny fluid every 20k and the car is perfect tranny wise. Either way the tranny was designed to go much much further than 65k. Any maintenance done to date on the tranny?
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    May 13 2008
    NoCal - EBay
    Just read over the OP post:::
    Has this car had any of the mounts mentioned above changed ur upgraded yet cause that is the 1st place I would look.
    'SOFTWALKER MODS
    Avant>Sedan! Click
    Aug 17 2009
    Pittsburgh
    could be the snub mount needs changed...but i wouldn't think so. what OP described sounds like a trans. I would definitely inspect everything else first. changing the trans fluid on a TIP is not an easy task, or a cheap one if you don't have the right tools. it's not as simple as just changing the fluid and the filter, although i wish it was.
    Nov 17 2009
    Winnipeg, MB.
    Some great discussion here. I've not noticed any hesitation in power delivery, but I've only ever tried "parking lot speed" tests so far. I'll try some more tests in the morning to see under what conditions it happens. No mounts have ever been replaced so I'll check those too while I'm poking around. Thanks!
    Senior Member Two Rings fcamargo6thave's Avatar
    Apr 08 2007
    hey did u get this fixed what was the problem
