Results 1 to 19 of 19
    Senior Member Three Rings amoujaffar's Avatar
    Jan 30 2010
    cleveland Ohio
    Oil Change Woes :(
    Hey everyone, last night I did my 1st oil change on my 04 with the whole kit from JHM (LubroMoly/Hengst). Also changed to a KNN and got it all back together. But today everytime i turn it on it get a horrible noise from the chain, and no not the "normal" clang that all our cars make on a cold start, this is far more intense, then gone in a few seconds.
    Is there any way that the chain is "getting used to" the new oil (found the old owner had a fram filter so oil couldn't have been too great) or maybe sometig else I'm not thinking of, either way its a noise that makes your stomach drop everytime you hear it.
    2000 Passat GLX 2.8 5-Speed (Totaled)
    1995 Wrangler 2.5 5-Speed (Sold)
    1968 Oldsmobile Delta 88 455CI (Sold)
    2004 Audi S4 4.2 6-Speed - RS4 Rims Hankook Ventus V12's, , Stock rims with Dunlop Wintersport, 30% Tint all around, Lifetime Sat Radio. Piggies.
    Coming Soon: Tinted Tails, Magnalflow, JHM Intake Manifold, JHM Tune, SS Lines, Short Shifter
    Sep 21 2008
    Toronto, Canada
    pretty sure it's due to the fact that your oil filter is empty and needs to fill up before oil gets pumped to your moving engine parts.
    To minimize the time the engine gets starved of oil, fill your oil filter with as much oil as possible before screwing it on....
    Jan 30 2010
    cleveland Ohio
    hmmm didnt fill the filter, but I have started it all day long. Should I still take it back off and fill?
    BTW what is the specific amount I'm supposed to put in in Liters?, I went by the dipstick
    Veteran Member Three Rings Reggie's Avatar
    Feb 27 2005
    2014 SQ5 & 2015 RS5
    Fort Collins Coloardo
    No it got filled after pressure was restored.
    So what oil are you using?
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Quote Originally Posted by kbjy11 View Post
    We dont have the same oil filters as the B5. Ours are top mount paper filters. Its a cylinder than can't be filled with oil.
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Quote Originally Posted by amoujaffar View Post
    Something like 9.5 quaters, but you should go by the dipstick anyways because you may not have removed all the oil when you drained it.
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Frisco, TX
    9.5qt is the fill for the S4/RS4.
    now: 2021 Mercedes AMG C63 S, 2017 Chevrolet Corvette Grand Sport
    past: 2005 Audi S4, 2011 Audi S4
    Active Member Three Rings AndyGs4's Avatar
    Jan 26 2010
    Right here.
    this is your first oil change?
    The timing tensioners are very specific when it comes to proper weight. Do you know what the weight of the oil was run by the previous owner?
    The lubromoly that you refilled with is the correct weight (assuming you purchased the oil from JHM for S4 V8). how much new oil went in? Did you get most of the old oil out?
    I would be half tempted to take it into a shop and get a diagnostic/oil change/full service. Assuming what you are hearing is timing tensioners, the fact that they got MORE NOISY after an oil change is very suspicious. I wouldn't screw with it.
    2004 S4
    JHM Headers - FI Catback - K&W Coilovers - JHM B7 LW Flywheel - JHM LW Pulley - Apikol Snub - 19" Neuspeed RS10s - Stern MM
    Audis - 86 5000CS Turbo sold at 150K - 95 A6 sold at 177K - 00 Jetta 2.0 got hit at 220K
    Resto - 55 Chev3100 Stepside - 68 Mustang Coupe - 73 Mach 1
    ...w.w.w...e.u.r.o.a.d.d.i.c.t.i.o.n...n.e.t...
    Apr 24 2009
    Frisco, TX
    I don't understand, are you running a K&N oil filter or the Hengst one?
    Jan 30 2010
    cleveland Ohio
    running a hengst oil filter, the KNN was for air.
    I filled about 8 liters (yes got the lubro-moly 5w-40) the dipstick seemed right to me. I may need to add another quart or so.
    PS this is NOT my 1st oil change haha, just first one on this car. I'll go check the level in a second.
    PS i only let the engine cool down for about 15 minutes, then let it drain for about an hour (really wanted to get everything out), i even leveled the car towards the drain side a few degrees to get as much as possible out
    Jan 30 2010
    cleveland Ohio
    Apr 24 2009
    Frisco, TX
    8L? That's only 8.5qt. Odd.
    Jan 30 2010
    cleveland Ohio
    for referance what mark are you guys using on the dipstick. im looking at the nub on the 2nd orange piece (towards the top)
    Veteran Member Three Rings V8weight's Avatar
    Nov 16 2008
    Hudson, WI
    It should be in the crosshatched area between the two orange plastic nubs. If you were filling the oil according to the dipstick, be aware that after you start the vehicle it will consume an additional quart due to the filter cartridge filling once oil starts to circulate.
    - Pat -
    2016 RS7
    -Previous-
    2013 S6 Prestige, 2010 A6 Prestige/Sport package, 2012 A4 Avant S/line, 1991 Coupe Quattro, E55 AMG, 2009 A4 Prestige, B5 S4 avant, B6 S4, C5 RS6, B6 S4 avant, 71 El Camino SS
    Apr 24 2009
    Frisco, TX
    ^ Yep. Sounds like you need a bit more oil.
    Jan 26 2010
    Right here.
    ^^^ Fill to crosshatched area...
    2004 S4
    Mar 09 2010
    mk4 golf gl (yup... a gl), b6 s4
    Ashburn VA
    I was going to buy one of those kits from ECS... 8 quarts? Who are the kidding? Always buy extra oil. I buy two 5-qt. bottles when I do oil changes. My VW burns oil like no one's business so having extra in the garage is always a plus.
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    He bought the JHM kit. Comes with 10L of oil.
    Apr 24 2009
    Frisco, TX
    Yeah the JHM kits are 10L so you should have some extra for top-offs.
