Results 1 to 21 of 21
    Established Member Two Rings kagangen's Avatar
    May 29 2008
    Mercedes GL450
    New Jersey
    Try this again-Spacer Question
    What size spacers would be optimal for 19x8.5 wheels with a 42 offset? Tirest are 245/35/19. Also, who makes the best ones for the money?
    Thanks Jeff
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Are you lowered?
    Most people would aim for offset of 35 with 235s on a 8.5 inch rim...that makes it pretty close to rubbing, but still clears. So I'd say anywhere from 3-5mm in the back, maybe slightly less in the front. This all depends on how low you are.
    May 29 2008
    Mercedes GL450
    New Jersey
    im not lowered at all. does this mean i shudnt bother with spacers?
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    I would say sometimes spacers look odd if you're not lowered.
    Your new set up will still be sticking out 9mm further than stock (Stock 18x8 avus wheels that is...not exactly sure what you're actually running right now.)
    Veteran Member Four Rings Cargo8's Avatar
    Dec 06 2006
    Could go 7 safely on front and rear.
    rear could go up to 10 (guessing now). 8.5 with a /245/ tire and ET 35 is perfectly flush up front, and tucked a tiny in the rear, hence the +3 mm guess I'm giving you
    i'd say 7/10
    Active Member Three Rings AndyGs4's Avatar
    Jan 26 2010
    Right here.
    Apikol makes 5mm spacers for these cars.
    Not to change your topic too much, but there are a lot of wheels out there with 33-35 offset that don't req any spacers. I personally avoid spacers for wear and performance reasons; if you haven't already purchased wheels..it's something to consider........IMO
    2004 S4
    JHM Headers - FI Catback - K&W Coilovers - JHM B7 LW Flywheel - JHM LW Pulley - Apikol Snub - 19" Neuspeed RS10s - Stern MM
    Audis - 86 5000CS Turbo sold at 150K - 95 A6 sold at 177K - 00 Jetta 2.0 got hit at 220K
    Resto - 55 Chev3100 Stepside - 68 Mustang Coupe - 73 Mach 1
    ...w.w.w...e.u.r.o.a.d.d.i.c.t.i.o.n...n.e.t...
    Established Member Two Rings KOOL WIP's Avatar
    Jun 15 2009
    05 Arctic S4 56 Oval Beetle
    Ohio
    I have 19x8.5 up front. And 19x9.5 in the rear. Both are ET41. I use 5mm spacers all the way around. No rubbing issues. Had to use spacers to work around the brakes. Just to give you an idea...
    Veteran Member Three Rings rzundel's Avatar
    Sep 20 2008
    Ferrari Challenge Stradale, Maserati GranTurismo S, Range Rover HSE, Porsche Panamera
    Westlake Village, CA
    7mm front and 10mm in rear for edge of fender fitment. You could go up to 5mm and retain your stock lugs if you wanted to play in safe.
    2005 Audi B6 Tip
    HRE M40 20x8.5 et34, HANKOOK Ventus V12 235/30/20, BREMBO 6pot Front BBK, BREMBO 4pot Rear BBK, KW VARIANT 3 Coilovers, LABREE Res Cat Back w/4" tips, GIAC ECU Flash, AE Corner Balance + Alignment, HOTCHKIS RS4 H-Sport F&R Anti Roll Bars, STERN Adjustable Control Arms, AE PERFORMANCE Black Optic Hood and Bumper Grilles, Clear Corner mod + Silver bulbs, Rear Valence Painted Satin Black, 30% Window Tint, Front Clear Bra, RS4 Pedals.
    May 29 2008
    Mercedes GL450
    New Jersey
    thanks for your input
    Sep 22 2009
    AC Cobra Replica (sold), B5 S4 (sold), B6 S4 (sold), Mazdaspeed 6 (sold), Joined dark side E92 M3
    collegeville pa
    How about stock b6 s4 with HR springs? What size spacers?
    Veteran Member Four Rings Eddie Man's Avatar
    Nov 05 2004
    Detroit/Clarkston
    Once you settle in on your spacer size, ALWAYS go with Hubcentric Spacers for a vibration free riding and foolproof installation.
    Don't forget to get longer wheel bolts to match your spacer width.
    2006 S4 Avant
    dolphin gray | 6speed | alcantara | premium | cold | bose | sirius | navigation | bluetooth | parktronic | ebony | carbon fiber
    >>> Got Mods?
    Sep 22 2009
    collegeville pa
    A lot of answers.. I am completly stock with HR sport springs.. AWE said 15 front 20 rear, but this sounds like it wouldnt work.
    Sep 22 2009
    collegeville pa
    so I am able to get a good deal on a set of HR hub-centric 20mm front and back.. to bold? Running stock wheels and HR springs.
    I also need to get the lugs.. what size and type?
    Senior Member Two Rings wva s4's Avatar
    Jan 19 2008
    Charleston,WV
    I just bought 17.5 mm from ECS for my stockers to clear my RS front brakes....very close to the lip of fender, but I believe its going to be ok....
    Iroz downpipe/midpipe * Iroz Intercooler * Iroz Boost Tap * Iroz DSG Catch Can * Iroz Haldex Switch * Iroz turn down pipe * APR Inlet * IE Intake * Unitronic ECU/TCU Tuning * Innovate ECB-1 Gauge * WaveTrac Limited Slip Differential * KW V3's *Whiteline Swaybars * Vinny’s Custom Dog Bone Mount *Titan T-S5 Wheels
    Veteran Member Four Rings whartung's Avatar
    Feb 01 2007
    Quote Originally Posted by dbc112 View Post
    I just put 20mm spacers on the rear and 12mm's up front with stock rims, and everything looks perfect and flush. I've had a few rubbing issues in the rear and have progressively had to raise my rears up, but I have an alignment tomorrow so today was the last day I could do that. Currently the fronts are at about 25" wheel to fender and the rears are a bit over 25 1/4" Hopefully the rubbing will be gone on anything but the biggest bumps w/ 4 people in the car.
    20MM up front would be too bold I'd think.
    And get lugs that are however large the spacer is larger than your stock bolts.
    Sold: 2005.5 Sprint Blue Pearl Audi S4 Sedan 6MT
    Corsa w/ 12" Resonators - Vogt GT's - Trexturk Catless Downpipes - JHM Tuned - JHM SS - JHM Intake Spacers - JHM/Apikol Rear Differential Mount - JHM LWCP - K&N - RS4 Sway - Blackout Grille - ClearCornered and Blackedout Headlights - Xeonmatch - ECS Snub
    Sep 22 2009
    collegeville pa
    I passed on the deal.. After reading several threads, I am going 12/17
    Established Member Two Rings Trevor Ely's Avatar
    Apr 14 2009
    '88 E28 535is, '00 B5 1.8TQMS
    Hickory, NC
    That's probably wise...Like mentioned above, without suspension there's no need to go too extreme, because it can start to look odd.
    Trevor Ely
    '00 A4 1.8TQMS - '85 2.3-16 (Euro) - '95 540i M-Sport (1 of 200) - '09 M3/4 - '91 M5 - '12 Fiat 500
    Gone: '88 535is - '87 325e - '89 325is - '91 318is - '90 325is - '96 328is
    Established Member Two Rings ADynamics's Avatar
    Oct 06 2009
    Sprint Blue B7 S4
    Tri State
    Your ET 42 with 245R19 tire won't rub. Car will work fine up to ET 45 with 245 tire including having clearance to the control arms for the time being.
    Feb 01 2007
    In hindsight I'd get 15 mm spacers for the fronts. 12 aren't doing it for me cause of the negative camber pushing the tops of the wheels inwards...
    Veteran Member Three Rings RBSileighty's Avatar
    Jan 08 2010
    FL
    Quote Originally Posted by whartung View Post
    I'm at a similar ride height and you are right about the 20mm spacer up front... that would put it 1mm inboard of where mine sit (9.5 +33) and I had to pull my fenders, and since yours are 8.5's w/ spacers it doesn't make a lot of sense to run a spacer that requires a pull.
    Sep 22 2009
    collegeville pa
    So whats the call with stockers and HR springs? 15 front 20 rear? I really dont want any potential rubbing issues. I frequently have 2 kids and the wife in the car. Not that the will weigh a ton... also the roads in PA are not fun, so dont want to cause any issues etc.. .
    So maybe 12 and 15?
