    Senior Member Two Rings cmorse's Avatar
    Oct 23 2006
    virginia tech
    spark plug compatability FR5DP1
    Does anyone know what is comparable to the Bosch FR5DP1. This is what came with my mtm k04 kit and I would like to replace them. However, when I go to get new ones, no one know what they are. Any ideas on what else I can use.
    Thanks
    Veteran Member Four Rings dcampana's Avatar
    Nov 01 2006
    04 Allroad, 01a41.8Q
    Nor Cal
    you can buy them from 034 motorsports
    my ride: 2001 A4qtm... 2871r, 440cc, 3 bar, turbo xs dv, custom 3" exhaust, test pipe, Cm fx400 billet LWFW...
    2004 AR... stage 1 DAZ tune
    Timing belts, clutches, and all done in the North Bay. Pm me.
    Oct 23 2006
    virginia tech
    I didnt see them on thier website. I was hoping for something a little cheaper then the $60 I spent on the original set.
    Nov 01 2006
    Nor Cal
    you can run other plugs... I run the same plugs as you...
    you can run a bkr8 plug ( IIRC- the higher the number the colder the spark...)
    981CGTS, Cayenne Turbo, '22 A4 Allroad
    Chicago 'burbs
    I have a low mileage set from when I parted out my MTM kit. They were probably in the car less than 3k miles.
    Other than that Anderson Motor Sport in MN use to be an MTM dealer and Keith would be able to help you out on that one.
    2014 A4Q Red w/ black optic black interior
