Results 1 to 11 of 11
    Senior Member Two Rings EuRo_KiD's Avatar
    Jul 30 2009
    2001 Audi A4 1.8T Quattro
    PA
    Possible brake fluid leak?
    Ok, so i have to pour brake fluid like every 3 days man! My question is, where could it possible be leaking? Any known issues with this? Also, the top of the containter where i pour it in seems like it has some brake fluid on it but i didn't spill any? I'm confused so please someone help
    01 A4 1.8TQ "Low and Slow"
    WTB: GIAC chip (AWM), Forge 007 DV
    Soon to come: Custom Exhaust, Chip, Upgraded DV
    Account Terminated Three Rings lotusgardener's Avatar
    Dec 24 2006
    1997 Audi A4
    NW & NE
    Check under your booster. If no there look around your tranny for leaks.
    Jul 30 2009
    PA
    Hmmm ok i'll have to check that tomorrow. Anybody else?
    Jun 14 2005
    Anaheim, CA
    have you changed anything with your brakes lately? When I got SS lines, it wasn't sealing properly, and fluid was coming out of the caliper area.
    Brandon @ VMR Wheels
    Veteran Member Three Rings Übermensch's Avatar
    Nov 11 2009
    OLS
    Quote Originally Posted by VMRWheels View Post
    x2 on the improper seal when changing brake-pads
    Jun 30 2008
    Erie, Pennsylvania
    A common "technician-induced" failure is a torn caliper piston boot. There are 2 main causes.
    - During compression of the caliper piston. If done with a large pair of pliers, one must take care that the plier's "teeth" do not touch the boot, else it can be torn. Using the proper caliper piston tool avoids this risk altogether.
    - During re-installation of the caliper. Especially if the piston/boot is not *fully* compressed back into the caliper, the boot can make contact with the edge of the new pad, possibly tearing it.
    It usually happens if the technician/diy-er is careless or isn't using the proper tools. Also, if the tear is not complete, the problem can surface later. Usually, the damage is fairly obvious that it was caused by the tech.
    Other things to check (for leaks):
    - Hydraulic clutch system
    - Brake fluid reservoir - I seem to recall a few people needing replacement reservoirs. Perhaps they are a somewhat common failure. I can't recall the reason.
    - Obviously rusted lines or leaky fittings, etc.
    Jul 30 2009
    PA
    Well guys, i woke up this morning to take my girl to work and i have no brakes!!!! When i press the brake pedal down it goes to the floor like it has no pressure!!!! :(
    Jul 30 2009
    PA
    Oh and on another note, I haven't changed anything with my braking system at all. This started happening a week ago. I would get 3 beeps and a flashing "BRAKE" light which means that the brake fluid is low. But, when i fill her up with DOT 3&4 synthetic brake fluid, it only takes like 3 days and she's empty again.....
    Veteran Member Four Rings bw86's Avatar
    Dec 06 2008
    2.0L 058
    LI
    So fill it back up have a friend look under the car/hood and keep pressing the brakes, looking for leaks
    Dec 24 2009
    03 1500 Silverado /95 2500silverado/97 4runner/2010yz450f//93 inter. 98 A4 2.8 pearl white
    clarence NY
    If a wheel cylinder or caliper has bad seals you should see oil all over the inside of your tire. Sometimes that will not leave a puddle for you to readily see, where as a bad line/connnection will. When your moving down the road it[oil] will fly off the tire so that when you park there might not be a patch to be seen.Take a light and look under the car and hood for any obvious leaks.There has to be a place where it is coming out.
    Jul 30 2009
    PA
    ^^^ WE have a winner!! It was the driver side caliper that it was leaking from. I'm getting it replaced monday :) Thanks for everyone's input guys!
