Results 1 to 13 of 13
    Senior Member Three Rings jeradw's Avatar
    Jul 18 2009
    2008 A4 (his) 2010 Tiguan (hers)
    Wisconsin
    Any Plastidip Tips?
    I am going to plastidip my trim on Saturday and am looking for some pointers/tips. I have already "plastidipped" my trunk strip, but I was able to take it off and do it that way. I really like the way the 5 coats have been holding up on the trunk strip (absolutely no cracking, or flaking away like normal paint!! ) However, this is not going to be the same beast because I cant actually take the trim off.
    I was thinking about playing with notecards to get them to stick inbetween the car and the trim as there is a small gap and then spray...letting it sit for a couple of minutes and then removing the cards (I didnt want to let the cards lay there too long because I dont want the plastidip to stick to the notecards). How does this logic sound?
    Otherwise, I was debating about some painters tape. Perhaps a combination of the two?
    Does anyone have any ideas? Any other helpful hints are, of course, welcomed.
    I have already read through this thread (thanks for the writeup nnnick)
    http://www.audizine.com/forum/showth...-up-B7-edition
    Thanks guys!
    Jerad
    2008 Tip A4 Special Edition - Brilliant Black
    18" Enkei EKMIII Gunmetal (summer) // Hyper Silver (winter) | 35% Tint | Eibach/Koni FSD Street Kit | de-Badged
    AWE Diamond Black QuadTip | Blackout S-line Grille | Ti Trim | Color Matched Front Reflectors | Smoked Side Markers
    Front Filler Plate (Black) | Plastidip'ed Trunk Strip (Black) | K&N Drop-in | APR 93 Stage I
    Aug 17 2009
    Pittsburgh
    however long you think it will take you to paint, multiply that time by 3 and that should be your prep time, so if you're going to paint for one hour, plan on a 3 hour prep time. seems a bit excessive i know, but painting a car, any piece of a car, is all about preparation. my advice is to remove the bumper, and invest heavily in GOOD painters tape, 3m green is what i prefer. then go to your local newstand and buy up a few newspapers. sunday papers are the best because of the inserts. paint wont bleed through the heavy paper in the inserts. this is way cheaper than buying masking material. mask everything off front and back that you don't want to paint. there is a reason for this. once you think everything is covered well, go over it again and make damn sure. even with plastidip i prefer to scuff the surface for better adhesion. use a high grit sandpaper, 320 or 400 is fine. wet sand to scuff! a bottle of window cleaner is great because the little bit of alcohol help dry and clean the surface area after your done. do wet coats. hold the can/gun about 8 inches away and let 'er rip. just enough to cover the piece, but not enough to cause a run. 10 more minutes and repeat. 10 more minutes and repeat. wait til the next day and if you're happy, you're done. if there are any runs(shouldn't be right?) get out your 400 grit and your spray bottle. this time warm water and just a drop of non-abrasive dish soap. just a bit of light sanding, preferably with a block(finger grooves will show up, but probably not on something small like trim). Now you're done. re-install the bumper/trim piece and voila, new look!
    enjoy
    Aug 17 2009
    Pittsburgh
    just read that other write up...i guess i didn't need to post...
    Veteran Member Four Rings nnnick's Avatar
    Nov 01 2005
    2006 S4 6MT
    La Jolla, CA
    do you mean like the window trim? or interior trim? the latter comes off really easy. For window trim I bet cards and tape would be a good combo, and then maybe also put down a fresh coat of polish before you get started so that the paint has a little protection on it and any overspray will wipe off easy?
    I'm curious to see how this works out - I'd love to do the same! Glad my other write-up was helpful :)
    Current: 08 R8 6MT, 14 Cayenne GTS, 98 Saleen XP8
    Past: B7 RS4, '12 Audi TTRS BT Build | 2006 Audi S4 HPDE Build | 2006 Audi A4
    Visit my blog: NicksCarBlog.com
    Established Member Two Rings mmarktfsi's Avatar
    Sep 30 2008
    2007 Dolphin Grey A4 2.0T
    Winter Park / Gainesville, FL
    Quote Originally Posted by hercfe View Post
    enjoy
    Good write up. I'll follow it as well when I PD my grill and rear bumper trim.
    Veteran Member Three Rings maidest's Avatar
    Oct 29 2009
    I agree with the long prep time. I did my window trim, grill trim, and trunk trim, without removing them from the car. It took me a really long time to prep with 3m painters tape and masking paper. Make sure you pay very close attention to detail when you're taping because if not it is very easy to make mistakes. Also have an exacto knife ready to cut the plastdip down the sides of the trim so it doesn't stick to the tape when you're trying to remove. All in all, it is a very tedious thing and is easy to fuck up. MAke sure you put in the time and it will come out good and be well worth it.
    06 A4 2.0tq 6MT
    APR Stage 2||RAI Downpipe/Test Pipe||EvoMs Intake||VAST W/M kit||HID 6000K||LED City/LP lights||RS4 stealth turn signals||CC'd blacked housing||Pioneer Avic||Passport8500 X50 Red Hardwired||35% all around||Smoked F/R Reflectors||RS4 Grill Blacked||TSW Nurburging RF Gunmetal 19x8.5 et32||Conti ExtCon DWS 225/35||8mm rear spacers||Koni FSD Eibach Pro Kit||Red Calipers||Votex Front Chins||ABT Trunk Lip||Memphis 6.5" Speakers||Memphis 12" Sub||Memphis Sub/Speaker AMPS||VAG'd
    Jul 18 2009
    Wisconsin
    So you leave all the paint/notecards or whatever you are going to use for protection on until the end and then just cut it so it doesnt stick?
    Still not sure why I have to take the bumpers off if I am painting the outside window trim... ??
    Jul 18 2009
    Wisconsin
    Ohh yeah...what if it already has paint on it? Its been painted twice, but it keeps chipping so I want to try this now. Should I take all of the paint off, sand it down and then paint?
    Nov 01 2005
    2006 S4 6MT
    La Jolla, CA
    Quote Originally Posted by jeradw View Post
    LOL!
    yeah u should probably bleed your brakes, change your oil and rotate your tires too...otherwise the paint might chip!
    If there is already paint there, it's fine...but it will be harder to remove the plasti-dip down the road (could be a good thing actually). Plasti-dip comes off the metal/chrome surface a lot easier than something painted....
    I really like the metric spend 3x as long prepping than painting, although with plasti-dip I don't think that's totally necessary since its textured and so its not like the surface has to be completely smooth even.
    Oct 29 2009
    you don't have to sand at all, and it will be fine over the two layers of paint. And yes I left the tape on until it was mostly dry and just used the Xacto to make sure it wasn't sticking. But yes, make sure you take off both bumpers, disassemble the doors, and swap the entire engine while you're at it.
    06 A4 2.0tq 6MT
    Jul 18 2009
    Wisconsin
    Quote Originally Posted by maidest View Post
    lol... :P
    Jan 01 2008
    Long Island NY
    I painted my friends entire jetta with plastidip in my garage lol..
    Sep 17 2009
    miami
    FUCK PAINTERS TAPE!! Tapeing shit off with plasti dip is a BITCH!! i spent two days because i didnt want to take off the emblems and re apply them.. So i did the window trim, Grill trim, Trunk strip and all the emblems using tape.. and DONT LET IT DRY TO THE TAPE!! Since its rubber it wants to peel off with the tape.. "just use a razor" STILL a pain in the ass.. because it doesnt want to cut the plasti dip.. it chews it up..
    DO YOUR SELF A FAVOR AND VINYL THE WINDOW TRIM!! and if you do the emblems take them off and spray them..
    Dont go through the nightmare i did just to want to redo it.. Plasti dip is great for certain things.. Grill, Trunk lip emblems.. but skip the trim.. trust me..
    2005.5 A4 Dakar beige - 18" VMR gunmetal v710 - Stage 1+ Unitronic
