Results 1 to 14 of 14
    Veteran Member Three Rings MisterQuattro's Avatar
    Nov 05 2009
    Long Island, New York
    HFC Test pipe im so confused
    SOOOO i like the way test pipes sound but I really dont want to get a ticket or deal with that stuff. So with that I plan on getting stasis exhaust later on. I guess my question is are HFC illegal and if not what are good ones to go with
    Thanks
    - Rizzo
    2011 Audi S5 - Fully Loaded -
    [RS5 Honeycomb Grill][AWE Track Exhaust][HID Fogs][LED License Plate Bulbs][Vagged]
    2006 A4 2.0T Stage 2+ ~ SOLD!
    V8 Club
    RIZZLES
    Veteran Member Three Rings maidest's Avatar
    Oct 29 2009
    I've heard good things about the FUCKIN' SEARCH HighFlow Cat. Not sure though, not a doctor.
    06 A4 2.0tq 6MT
    APR Stage 2||RAI Downpipe/Test Pipe||EvoMs Intake||VAST W/M kit||HID 6000K||LED City/LP lights||RS4 stealth turn signals||CC'd blacked housing||Pioneer Avic||Passport8500 X50 Red Hardwired||35% all around||Smoked F/R Reflectors||RS4 Grill Blacked||TSW Nurburging RF Gunmetal 19x8.5 et32||Conti ExtCon DWS 225/35||8mm rear spacers||Koni FSD Eibach Pro Kit||Red Calipers||Votex Front Chins||ABT Trunk Lip||Memphis 6.5" Speakers||Memphis 12" Sub||Memphis Sub/Speaker AMPS||VAG'd
    Nov 05 2009
    love the sarcasm not trying to skip steps but i would like it if guys who have experiences could tell me directly as opposed to searching over 50 threads for 1 small answer idk not a psychic or anything
    V8 Club
    RIZZLES
    Established Member Two Rings Shwabmyknob's Avatar
    Sep 14 2008
    E90 335I B8 A4 2.0T AQ
    Albany, NY
    That was un called for. To answer the OP's question, high flow cats are not illegal and as far as brands take your pick. Most are pretty good unless its a cheap ebay one with shitty welds. As far as the test pipe goes if you plan on tuning it I would just go with the test pipe as they can turn the CEL off. I just passed inspection with my test pipe. A cop isn't going to be able to tell if you have a cat or not.
    DTOM
    INSTAGRAM: GLOSSTRADAMUS
    Nov 05 2009
    well my friend got pulled over and the cop gave an emissions and decible test. With the hfc it will do a cel?
    V8 Club
    RIZZLES
    Sep 14 2008
    Albany, NY
    The cop did an emissions test? How? The HFC will not make the CEL come on.
    DTOM
    Veteran Member Three Rings Coyote USP's Avatar
    Oct 03 2008
    '78 Honda CB750K
    Dallas
    I gotta say for all the more senior members on here, in case you didn't notice the Search function is actually pretty jacked these days. I liked the old way a lot better, it made narrowing your search a lot easier.
    Check out 034 Motorsport for a BAD ASS HFC....well worth it, you can find sound clips and shit on YouTube
    USP CLUB MEMBER #123
    The Awesome™
    Kyle
    Sep 14 2008
    Albany, NY
    Indeed, it pulls up a lot of stuff not related to the search. Anyways here is a link to the 034 http://www.audizine.com/forum/showth...-Flow-CATS-***
    DTOM
    Nov 05 2009
    ok thanks so far guys any other words of wisdom and besides the actualy HFC what else do I need?
    V8 Club
    RIZZLES
    Nov 05 2009
    what are these options used for ?
    B7 Cat Hardware Kit
    Add O2 Sensor Spacer:
    V8 Club
    RIZZLES
    Oct 03 2008
    '78 Honda CB750K
    Dallas
    The hardware kit is probably bolts and gaskets, you'll need those unless you're planning on reusing your old stuff (probably not recommended). The o2 spacer is to decrease the likelihood of getting a CEL (don't ALWAYS work but it helps)
    The Awesome™
    Kyle
    Sep 14 2008
    Albany, NY
    You shouldn't need the 02 spacer for the HFC its more for the test pipe. I highly recommend the hardware kit. Chances are a nut or bolt may break because of the extreme heating/cooling sessions. Also if you try and reuse the gaskets it won't work and you will always have an exhaust leak.
    DTOM
    Oct 03 2008
    '78 Honda CB750K
    Dallas
    BTW I just looked at the Search, and they HAVE added a bunch of stuff that used to be on there
    The Awesome™
    Kyle
    Sep 14 2008
    Albany, NY
    Good to hear, Good luck with you HFC/Test pipe search. Post up some reviews about which ever product you decide to go with.
    DTOM
