Results 1 to 9 of 9
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    Is -8AN (1/2") line big enough for a catch can.
    Hey ziners
    I been reading up on this oil catch can thing and have a question. I plan on using the 034 block breather adapter and running that to a T at the valve cover and then into a vented can.
    would 1/2" (-8AN) lines be large enough to vent both the block and valve cover or will i have issues causing gaskets and seals to leak?
    Please help me out with this and im sure it would help out others too.
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Nov 09 2006
    Bronx, NY
    Bump, Bump Bump it Up.
    Anybody have any idea? im sure a couple people have catch cans installed. Im more interested in the block breather as i seen the valve cover with 3/8" line
    2000 A4 1.8tq
    Veteran Member Four Rings gotboost's Avatar
    Nov 04 2007
    Minnesota
    i would do -10
    Current:
    2002 A4 Avant - Eibach Pro Dampers | Rev Motoring Springs | 034 Motor Mounts | 710N DV | Apikol Snub Mount | 18" S4 Peeler's
    2001 Imola S4 Satge 2+
    2003 A4 GT2871r 303 AWHP 291 AWTQ
    Oct 06 2004
    Minnesota
    I run a full 1" for my catch can. Where are you venting?
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Nov 09 2006
    Bronx, NY
    Quote Originally Posted by A4Rob View Post
    I was going to run the 034 block breather to a -8 adapter, run a line from there to the valvecover (tapped with a -8 T bulkhead fitting) then a line from the T to a catch can thats vented to atmosphere.
    I am a bit confused about running it to atmosphere or using a sealed can and pulling vacuum from the tip. also wasnt sure on the size of the line i need to run.
    thanks for the help
    2000 A4 1.8tq
    Dec 05 2007
    I was always under the impression that the lines needs to be sized specifically, due to the vacuum pressure. Guess I was wrong.
    Veteran Member Four Rings Jeff's Avatar
    Feb 18 2004
    Los Angeles, CA
    -8 AN fittings typically adapt to 3/8" lines, while -10 AN fittings adapt to 1/2" lines. I would go with a -10AN.
    Nov 09 2006
    Bronx, NY
    Quote Originally Posted by Jeff View Post
    On the russell performance site it shows the conversion differently. It says that the -* is equivalent to the "*" being the numerator of 16.
    so -16 would be 16/16 of an inch. -8 would be 8/16=1/2 inch. -10=10/16=5/8" and so on. I know that might not be completely accurate but thats what it shows on the site.
    2000 A4 1.8tq
    Nov 09 2006
    Bronx, NY
    bumping this up...
    Still need to know if -8 is enough. (running -10 isnt much more expensive, just need a bulkhead fitting for it and i cant find any) Also need to know if i should run vented or sealed. I know most run it vented but read on other turbo forums to run it sealed as the vac will help vent the crankcase by "pulling" out the air/contaminants.
    2000 A4 1.8tq
