Results 1 to 6 of 6
    Veteran Member Three Rings T0mat3's Avatar
    Oct 05 2008
    Montreal, QC, Canada
    Exclamation Hood release cable disconnected!
    So yea, my cable is loose, and i cant open the hood, which is a very bad thing if lets say.... i run out of oil, or anything else like that. Plus i have my suspension to put on once it gets here. I already took off the grill and its very tight in there. Anybody have a useful trick they want to share :)
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    get under the car with a flash light and a long prybar. push the latch manually with the prybar. just to the right side of center iirc, theres a tab you can push up on.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Veteran Member Three Rings DGAFxxx's Avatar
    Nov 27 2006
    Salt Lake Shitty, UT
    Quote Originally Posted by B5A4Kevin View Post
    I have had to do that before, just have to find the g spot. And then it will pop open.
    Hooray for boobies!
    Veteran Member Four Rings terraflata's Avatar
    Sep 14 2008
    '97 Audi 1.8TQM '97 Acura Integra 2002 Dodge Durango
    Chambly, Quebec, Canada
    Your car isn't being soo nice to you is it Mat? You need some sort of hook prybar, just move the latch to the right when facing the car. Let me know how it goes.
    MontrealAudiClub
    Oct 05 2008
    So is it easier to access from under the car or from the grill? because from what i can see from the grill i cant even fit a bent screw driver anywhere close to the "G spot" lol. And no, my car is driving me nuts with all the bouncing it does. Damn Ksports :@ I cant wait to get my OEM stuff in the mail
    Veteran Member Four Rings adr3naline fix's Avatar
    Dec 17 2008
    Sold 01 1.8T, 05 Mini Cooper S JCW, 04 ZX10R Track
    Milwaukee
    I use a long screw driver. This happen to me in the first 72 hours of owning the car.
    My car is SOLD
    2001.5 1.8TQM || GT2871R Hybrid Elim @ 24psi | Unitronics Custom | 307awhp | etc | $15k+ in parts alone
