Originally Posted by
jayiszraw
anyone know the spring rates on the following: h&r coils, Bilstein pss9, stasis street sports. thanks
====STaSIS====
:'''STaSIS Street Sport'''
:*Progressive Springs
:*Front: 450# Rear: 440#
:*Stasis adjusts height and dampening to “optimal” settings
:*Rebound adjustable off of car
:*Koni dampers
:*Koni springs
:'''STaSIS Track Sport'''
:*Linear rate springs
:*Front: 600-800# Rear: 900-1100#
:*Rebound adjustable while on car
:*Koni dampers
:*Koni springs
:'''STaSIS SL'''
:*Dampening not adjustable
:*Ohlins dampers
:*Hyperco springs
:'''STaSIS Motor Sport'''
:*Ohlins dampers (adjustable on car)
:*Ohlins external front adjustable dampers
====H&R====
:'''H&R'''
:*Threaded adjustable lowering
:*Non-adjustable dampening
====Tein====
:'''Tein Basics for Quattro'''
:*Front: 504# Rear: 671#
:*Non adjustable dampening
:'''Tein Basics for FWD'''
:*Front: 447# Rear: 503#
:'''Tein Super Street for Quattro'''
:*Linear Rate Springs
:*16 different dampening adjustments
:'''Tein Super Street for FWD'''
====Koni====
:'''Koni'''
:*Front: 450# Rear:440#
====Bilstein====
:'''Bilstein PSS9 A4:'''
:*Linear Spring Rates
:*Front: 515# Rear: 515#
:*9 Levels of dampening adjustment
:*On car single ratio rebound/compression adjustment knob
:'''Bilstein PSS9 S4'''
:*Front: 575# Rear: 575#
====KW====
:'''KW Varient 1 for Quattro'''
:*Front: 580# Rear: 470#
:'''KW Varient 1 for FWD'''
:*Front: 580# Rear: 380#
:'''KW Varient 2 for Quattro'''
:*Threaded adjustable lowerings
:*Infinite adjustable dampening
:'''KW Varient 2 for FWD'''
:'''KW Varient 3 fro Quattro'''
:*Infinite adjustable rebound dampening
:*14 levels of compression adjustments
:'''KW Varient 3 for FWD'''
====Vogtland====
:'''Vogtland'''
:*Progressive Front Springs
:*Linear Rate Rear Springs
:*Dampers are sourced from KW
