Results 1 to 10 of 10
    May 27 2009
    G35
    Toronto, Ontario
    Nikku Detailed: 17 year old BMW 320i.. grrr
    Ok so lets get started.
    This was a real tough one. I was very surprised when I saw the condition of the car. First off the car has been resprayed at least twice. Paint was measured
    to be as low as 36 and as high as 430. Yes i know. Not only that the clearcoat varied. While some areas
    were semi soft white others were super hard. So lets just say I had to pretty much use everything I had.
    I spent about 18-20 hours just on the paint and nothing else. I did not do any wetsanding as that would have
    taken too much time and considering the amount of variables I was up against I left that out and focused on the
    overall outcome. I was aiming for 75% but I think I was able to attain 80%. You be the judge.
    Anyways on to the detail.
    Wash
    Optimum No Rinse
    Groute Sponge
    Two Buckets
    Two Grit Guards
    Waffle Weave Drying Towel
    Buffing Towels
    Clay
    Riccardo Yellow
    Chemical Guys Synthetic QD for clay lube
    Paint Correction
    Meguiars M105
    Menzerna SIP
    Menzerna PF
    Menzerna PO85rd
    3M Ultrafina
    Tufbuf Wool Pads
    Sonus Yellow
    Sonus White
    Sonus Blue
    LC Yellow 4 inch
    LC Orange 4 inch
    LC White 4 inch
    LSP
    Collinite 476
    Window
    RainX
    Equipment
    3M Sungun
    Fenix TK10
    Halogens
    Positector 6000
    Metabo
    PC7424
    BEFORES
    Paint Measurement
    Detailing in Toronto, Ontario
    May 27 2009
    G35
    Toronto, Ontario
    During
    Apparently the hood was "repainted" and then apparently it was sanded to hell and yes with the
    low paint readings in the first place. Boy what can you do...
    So with the hood having such low paint readings varying from 36-70+ microns I had to be very careful.
    I made a call to the client to let him know the situation with the hood and how he would like me to proceed.
    He told me to do the best that I could and the best that I could it was. I settled on SIP, PO85rd and ultrafina
    but after each I took measurements so I'm within a comfortable means. The area where it was 36 microns I only went with
    one pass of Menzerna Powerfinish.
    Trunk.
    Yes... the trunk. It has been repainted at least once. It was just as much a headache as the hood
    without the low readings but boy was it touchy.
    Menzerna SIP broken down.
    After SIP wiped off.
    More compounding and polishing...
    May 27 2009
    G35
    Toronto, Ontario
    Refining stages...
    May 27 2009
    G35
    Toronto, Ontario
    Refining stages...
    May 27 2009
    G35
    Toronto, Ontario
    Some of the paint was so sensitive that wiping with my microfiber towel enduced marring...
    So to solve this issue I had to use minimal pressure. Talk about touchy.
    Applying 3M Ultrafina with Sonus Blue pad.
    Remember how it looked like before? Yea I know.
    FINISHED PRODUCT.
    May 27 2009
    G35
    Toronto, Ontario
    Thanks for looking.
    Veteran Member Three Rings ColinAndrews's Avatar
    Oct 29 2007
    Edmonton, Alberta, Canada
    Kudos on your hard work man. I think the outcome is exceptional with that you were given. Having so many different combinations of hard/soft paint is a nightmare. You must have had to test an insane number of pad/polish combinations.
    If I was the owner, I would be very satisfied with how many years you took of that car's age.
    Veteran Member Four Rings hoppy6698's Avatar
    Sep 10 2009
    2015 BMW M235i
    Yorktown, VA
    Incredible job given its age and poor paint work. I truly hope the owner is investing some $ into some wheels to match the stellar finish now. Would be a shame to let that look go to waste.
    "A man who won´t die for something is not fit to live." - MLK Jr.
    May 27 2009
    G35
    Toronto, Ontario
    Thanks for the replies guys.
    The paint was headache to deal with I think just for the polishing pad I used 30 or so.
    In terms of his wheels those are just his winters. He'll be slapping on his summers soon :)
    Jun 29 2007
    '99.5 Avant 1.8tqm
    Motorcity
    Why cant I find someone in my area who does this kind of exceptional work?
    The best I have found locally is someone who I will NEVER let touch my car again... They mad it look like they were prepping it for a used car lot
