Results 1 to 8 of 8
    Veteran Member Four Rings jayiszraw's Avatar
    Aug 03 2009
    swfl
    b5 s4 upgrade what lines?
    will stock lines be compatible to b5 s4 brakes? what about the ss lines that ecs sells? i searched and didnt get anything on which lines to use only using ss lines thanks
    2.7 swap in progress
    Aug 03 2009
    swfl
    anyone?
    Veteran Member Four Rings a4darkness's Avatar
    Dec 01 2007
    San Jose CA
    IIRC, stock lines are just fine to use. However, it will be quite beneficial to add the SS lines.
    Respectfully, skipping ECS's SS lines would be a good idea. They've been known to not attach correctly and often the outer covers won't effectively cover the steel lines. Recent example here. It's not worth the ~$10-$15 price difference for low quality lines.
    Here are some more proven options:
    StopTech Stainless Steel Brake Lines Front [DOT Compliant] via Eurocode
    http://www.ecodetuning.com/shop/cart..._detail&p=1226
    Goodridge Stainless Steel Braided Brake Lines F+R [DOT + TUV Compliant] via AWE
    http://tinyurl.com/ydzsa3q
    You should also PM or email Matt@EuropaParts for a quote on some SS lines as well. Don't think they have em on the site yet but certain they can source them for you. And they're close to you as well.
    Aug 03 2009
    swfl
    Quote Originally Posted by a4darkness View Post
    if i could +rep you i would. thanks
    Dec 03 2005
    2 pedals 1FG
    connecticut
    ECS lines suck. Fitment sucks. Don't buy them.
    Any SS line for the B5 S4 (front), B6 and B7 will fit. In fact, the Goodrich P/N is the same for all those.
    -Doug
    Dec 06 2007
    Goodrich is the best.
    -Kirk
    BetaAlphaTau Member #58
    Dec 01 2007
    San Jose CA
    I think you just did. ;-]
    Imaginary rep FTW.
    Quote Originally Posted by jayiszraw View Post
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Go with Goodrich, it makes the pedal feel nice
    2019 SQ5 Prestige
