Results 1 to 13 of 13
    Veteran Member Three Rings Polski's Avatar
    Sep 21 2009
    B7 S-line Avant 2.0TFSI 6SMT
    Montreal
    Ready..set.....Name that audi sensor!!!
    Hey guys...recently my driveway tore my front bumper off..literaly..and now this little sensor is dangling..is it important? can i just snip it off? were does it belong if not?
    And this is what the bumper looked like when i unattached the few clips holding it.
    (you can see the sensor in the background..)
    I fiber-glassed it from the back...its looking good , i'm just fabricating a new way for the bumper to hold on since all the tabs are gone.
    I'll post pictures once its back up!
    MontrealAudiClub
    Senior Member Two Rings mainer0311's Avatar
    Dec 05 2007
    01 mk4 tdi
    Durham, NH
    out side air temp sensor, just find a place for it.
    Sep 21 2009
    Montreal
    is it possible that it would cause my car not to start?
    I wanted to move my car today and it didn't want to start for about 5 minutes of trying...until it finally started
    This never happened to me before (car not wanting to start)
    Then i saw that this sensor was in the snow....would that be the reason?
    MontrealAudiClub
    Veteran Member Four Rings 97B518TQM's Avatar
    May 31 2009
    CA. USA
    Quote Originally Posted by Polski View Post
    hmm... shouldn't affect the car starting at all. Maybe your battery's voltage had dropped from the cold..?
    SOLD: B5 S4 Tial 770s with meth @652hp
    Current: C7 S6 - SRM +4mm RS turbos, SRM inlets, SRM fuel lines, DS1 stage 4 custom tune, HPFPs, X-pipe, H&R lowered
    May 31 2009
    CA. USA
    Sep 21 2009
    Montreal
    its currently 5 Celsius (41 F) and the the car didn't want to start 30 mins ago, as well the battery was fine..between 12v-14v.
    This winter, even at -35c (-31F) the car would start with no hesitation.
    Its the first time this occurs...and it so happens that yesterday the bumper had been torn off....that's why I'm wondering if there is a correlation between the two.
    MontrealAudiClub
    Senior Member Three Rings jpcallmotor's Avatar
    Jan 11 2009
    B5 A4 1.8T
    Chicago
    That sensor does not have anything to do with the car not starting. It merely tells you the outside temperature on your gauge cluster.
    Jul 01 2008
    Minnesota
    The computer accounts for temperature when starting. Im not really sure about outside temperature, but I know it looks at coolant temperature. What does your gauge cluster read for the outside temp?
    Sep 21 2009
    Montreal
    it reads normal outside temps, and the car has been starting perfectly ever since in the incident...
    I'm still curious if that sensor dipped in snow could have been responsible..even if its just a outside thermometer
    MontrealAudiClub
    Jun 30 2008
    Erie, Pennsylvania
    Nope. Engine uses Intake Air Temp (IAT) and Coolant Temp. It doesn't care about outside air temp. This sensor is used for the DIS display and for the HVAC (Climatronic) system.
    Senior Member Two Rings Baudi18t's Avatar
    Aug 10 2007
    '08 a6 3.2q, '14 Accord spt, '91 Toyota Mr2
    Queens, NY
    by any chance would any of you know where to but a new on, sorry for the thread jack.
    Nov 15 2009
    Derry NH
    Try any of the site vendors or a dealership. When your car wouldn't start, did you smell gas? Could be a coolant temp sensor. Sometimes when they fail they make the car think it's colder than it is causing the car to add more fuel and it floods itself. You should get the car scanned if it happens again.
    Veteran Member Four Rings Silverstreak98's Avatar
    Dec 11 2006
    Minnesota
    Quote Originally Posted by Baudi18t View Post
    Part Number for the ambient air temp sensor is: 8Z0-820-535
    Looks like its about $7 w/o shipping: Autohaus, Genuinevwaudiparts
    ~Brian
    1998.5 A4 2.8QT
