Results 1 to 7 of 7
    Veteran Member Four Rings arce909's Avatar
    Oct 08 2008
    So-Cal
    Just upgraded to rns-e...VAG code help please!!!!
    Just upgraded from symphony || to rns-e, and need help with the vag code, so that the navigation shows thru the cluster... Thanks!!!
    Veteran Member Four Rings a4audi4fun's Avatar
    Sep 28 2007
    2017 B9 A4 Technik 6 spd manual, S-Line , 2008 B7 2.0T Avant 6MTQS S-Line, Past-2005 B6 A4 3.0 6MTQS
    Vancouver, BC, Canada
    Quote Originally Posted by arce909 View Post
    Don't know for sure but at a minimum I would expect you need to modify the Module 17 Instrument Cluster, Adaptation Channel 62 to let the cluster know that the nav system has been installed.
    A062,0,CAN-Databus Infotainment (Installation List)
    A062,5,CAN-Databus Infotainment (Installation List)
    A062,6,+00001 = Radio (Optional)
    A062,7,+00002 = Telephone OR US-Telematics (Optional)
    A062,8,+00004 = Navigation (Optional)
    A062,9,+00008 = Telematics (Optional)
    A062,10,+00016 = Intrument Cluster (Standard - only coded with 2nd Component)
    Current:
    2017 B9 A4 Technik, 2.0T, 6 spd manual, S-Line, quattro with Ultra
    2008 B7 A4 Avant, 2.0T, 6MTQS, S-Line, Special Edition
    Past: - 2005 B6 A4 3.0 V6 6MTQS, 1998 B5 A4 2.8 V6 5MTQS
    Dec 30 2007
    08 A4 Black Avant 2.0T 6Spd
    Cleveland, OH
    Try turning off then on...... I think this is a known issue
    http://www.audizine.com/forum/showth...683&viewfull=1
    See post #15:
    http://www.audizine.com/forum/showth...OEM-Navigation
    Oct 08 2008
    So-Cal
    I'll give it a try & see how it goes... Thanks
    Registered User Four Rings Matt@EuropaParts's Avatar
    Dec 22 2009
    Piscataway, NJ
    On my car (B6), it was like this:
    1. Select address 17 - instruments.
    2. Select adaptation - 10
    3. Select channel 62 and read it.
    4. Add 4 to the value read in 3 and test it. (my old value was 17, yours may be different)
    5. Save it.
    Edit: BTW, you need a licensed cable to do this...the ebay cable won't code it.
    Oct 08 2008
    So-Cal
    I have a B7, hopefully it's the same I'll give it a shot.. Thanks Matt...does anybody know if it's the same B6 & B7??
    Veteran Member Three Rings plokm's Avatar
    Feb 19 2007
    Louisiana
    I did it with an ebay cable and it works.
    STG 17 (Instrument cluster) -> Adaptation -> Function 10 -> Channel 62
    +01 - Radio
    +02 - Telefon
    +04 - Navigation
    +08 - Telematics
    +16 - Instrument Cluster
    To add navigation, add +4 to the current value.
