Results 1 to 13 of 13
    Established Member Two Rings Sublimize23's Avatar
    Nov 24 2009
    Chester County, PA
    Airbag light - driver's side airbag igniter bad
    Hey,
    So I just got the car about 4 months ago, and driving the other day and the airbag light came on. Took it to the Audi dealership today and the people who worked there knew the PO of the car, and mentioned that he had problems with the light as well. They printed me out the full service history of the car, the TSB was performed on the connectors but according to the service notes, this was still a sporadic issue. Dealer quoted me $906 to fix, but assured me that even though the light is on, does not mean all the airbags are deactivated. What are my options here? I'm thinking of just finally buying vagcom and clearing the light, because by the service notes, he had the light reset 7k miles ago (I've had it for about 4k) and this is the first time it's been on. What should I do?
    Veteran Member Four Rings ocod's Avatar
    Feb 17 2009
    05 A4 1.8TQM, 05 Nissan Xterra, 99 Sea Doo Sportster
    miami
    Quote Originally Posted by ocod View Post
    here's the diy fix
    http://www.audizine.com/forum/showthread.php?t=289490
    when it's happen to me I always go underneath seat unclip connectors then plug it back in.
    Clear it w/vag and turn car off. Start car and see if light comes on again. If not all done otherwise clear again and turn car off.
    If light stays on it will turn off after a few cycles.
    Has to do like someone said about wire gauge they used. causes a difference in voltage which triggers CEL.
    Has someone moved you seat to cause wire to crimp or be pulled loose from connector.
    iirc it's the yellow one? but thread shows you which one.
    GL
    here's another thread
    http://www.audizine.com/forum/showth...ag-light-is-on
    KO4 APR Stage II+ // tt injectors // Podi SW gague // NGK BRK 7E .28 gap // 2.5" Test Pipe // Forge 007 DV //
    APIKOL Snub Mount // Stock N75 // 20%Tint // DTH FRP Skirts // 270 miles to empty // B7 key fob // 35W 5K HID's
    Nov 24 2009
    Chester County, PA
    Guess I'll try it myself.. I'll see what the dealer has put in there. Do I just use any wire? Or buy the kit?
    Feb 17 2009
    miami
    Quote Originally Posted by Sublimize23 View Post
    The kit is only available to dealers only
    try pm'ing szinkuti for wire gauge??
    Do you have a vag to clear it? Check connectors under seat though...
    Nov 24 2009
    Chester County, PA
    No I don't have a vagcom to clear it.. I don't even have a PC. need to borrow my parents', lol. I'm planning on buying the ebay cable and purchasing the software license, does it work on windows 7? I've tried searching many times but it doesn't really seem clear if the ebay cable even works.
    Feb 17 2009
    miami
    yes to ebay cable plus 99 dollar software reg. fee. Not sure if compatiable w/windows 7. There was a thread a while back iirc.
    search various audi/vw threads for vag cable you may get lucky. VWVORTEX had someone selling it w/a laptop a while back.
    haha you may want to edit having to borrow parents comp. will make you look noobish
    Nov 24 2009
    Chester County, PA
    Haha, whatever. I'm graduating college in may, then starting dental school in the fall and bought the car myself, but that probably won't matter to the haters.
    Thanks though, I will keep an eye out. If i can figure out how on this new system, I'll rep you
    Feb 17 2009
    miami
    no more rep system.
    But your welcome.
    post in the regionals for help w/Vag. Offer some beer..
    Congrats on Dental school. Went through similar curriculum and it will get easier after the second year when you start learning about your profession.
    Good grad present for school(computer).
    Nov 24 2009
    Chester County, PA
    Yeah that's what I keep telling myself.. gotta make it through the first 2 while watching the debt pile up.
    Nov 24 2009
    Chester County, PA
    OK sorry to bump an old thread, I pulled my driver's seat and there are already 2 butt connectors there to replace that factory connector. What now? Should I just solder the joint and get rid of the connectors entirely? That will be less resistance than any connector
    Nov 24 2009
    Chester County, PA
    For anyone who cares, soldering the wires cured the light. It had the dealer fix of 2 butt connectors, but it was again tripping the light due to too much resistance. Hopefully the driver's side airbag igniter isn't actually bad.
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    Not a fix/solution to the problem, but I was using VAGCOM with no problems on Windows 7. If you have problems with it, just right click and "Run as Administrator" and it should work then, although I think it may start up that way by default. I just downloaded the latest version from Ross-Tech and they state that it's W7 compatible there now as well.
    Feb 17 2009
    miami
    Glad it worked out..
