Results 1 to 21 of 21
    Senior Member Three Rings rick1.8t's Avatar
    Jun 15 2007
    2007 Audi A4 S-Line, 2003 Audi A4 GTRS
    Hillsboro, OR
    GTRS or BT guys....
    Are any of you experiencing problems with your axle assemblies. I've replaced mine 5 times in the past 2 years. It se4ems to be only the driver side one going bad every 4 to 5 months. I'm starting to think that the stock ones im ordering can not handle the power of the GTRS torque. I know its not a lot but its all i can think of. Any help is appreciated. Thanks in advance guys.
    Sep 12 2008
    South Central PA
    i would guess something else is wrong, especially since its only your drivers side that is going bad.
    EFR | 7163
    268/260 cams
    I.E. Intake Manifold / 70mm
    BoostManager+
    Meth Head
    Jun 08 2007
    Orlando, Fl
    Wowzers, 5 times? I've replaced my driver side once since being BT but I had 68k miles so I contributed it to the mileage not the BT.
    BetaAlphaTauMember #39 GTRS Powered/Revo Tuned
    Veteran Member Four Rings MmmBoost's Avatar
    Nov 29 2005
    10 A4 Avant S-line, 07 Suzuki GSX-R600, '69 VW Beetle w/ 1.9L aircooled turbo
    Edmonton, AB
    Something sounds out of alignment. Are your motor mounts still in good shape? Trans mount?
    ~Chris
    I sold my Audis and bought a Touareg... Catch me over at Club Touareg
    My B6 Avant GT2871R build
    Tumblr
    "Robert Bosch don't fuck around"
    May 24 2007
    Southern California
    never had to replace mine
    Kyle
    2.0L Revo GTRS Eliminator
    Jun 15 2007
    Hillsboro, OR
    I got a snub mount and the motor mounts were fine. The car only has 53,000 miles on it. Can't seem to figure out what would keep causing just the driver side axle assembly to keep going bad.
    Veteran Member Four Rings BARRY's Avatar
    Nov 02 2007
    SF Bay Area, CA
    is your car lowered? generally lowered cars will see adverse axle angles. that along with the added torque of more power could cause issues.
    Veteran Member Three Rings JustinCase's Avatar
    May 25 2007
    2013 A4, 2011 A4 Avant
    Scranton, Pa
    Lowered is what I was thinking too. But 5 is still a lot.
    -Justin
    2013 A4 Sedan
    2011 A4 Avant
    Veteran Member Four Rings Siggiepop's Avatar
    Aug 20 2007
    B6 A4 . Bus Pass
    Ontario, Canada
    this is interesting. Ill keep on eye on my axles
    CT4952
    Jun 15 2007
    Hillsboro, OR
    Yes it is lowered. Here is a pic for reference.
    Jun 22 2009
    Dundalk, MD
    thats nothing crazy. What happens when they are going "bad"? Is it split CV boots?
    Jun 15 2007
    Hillsboro, OR
    The boot was torn the first time, which i think was normal wear and tear. And every time after that i can feel the car shake and the car "clunks" when i turn left under load. If i just let the car idle around a corner it won't "clunk". The boot is not torn this time but anytime I accelerate the car starts to shake a little. As soon as i replace the axle assembly the car is fine for a few months then I start to hear the "clinking clunk" sound while turning around corners. I was hoping maybe someone else has experienced this problem.
    Jun 22 2009
    Dundalk, MD
    have you replaced any control arms on that side or just in general?
    Jun 15 2007
    Hillsboro, OR
    Not recently. Do you think they might be going bad or already have gone bad? Next step is to have the suspension step looked at while at the shop.
    Veteran Member Three Rings j-rod's Avatar
    Sep 09 2009
    VW Toureg V8
    Dallas, TX
    I really like those wheels. What are they?
    The Awesome™
    Web Design & Development
    www.jarodtaylor.com
    Jun 15 2007
    Hillsboro, OR
    They are 20" Stern ST-8 Wheels.
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    GTRS from Jan. 2006 to June 2008, Gt3071r from June 2008 to August 2008, GT3076r running from October 2008 to present and currently over 400whp. Still on the stock axles.
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Nov 02 2007
    SF Bay Area, CA
    possibly you are gasing it hard while making turns. a lot of this will cause the cv to flex and possibly cause issues in the future.
    Dec 01 2007
    Orange County, NY 10918
    Quote Originally Posted by rick1.8t View Post
    i like those stern wheels! my friend had a set of black ones on his W8 passat wagon.
    nice looking a4 by the way
    C6A6 3.0t Avant
    @avantneil
    @avantoberfest
    @skiguardusa www.skigaurd.com
    Jun 21 2005
    Milton, Ontario
    I have torn CV boots but on Stage 1+ car, 130,000 kms....replacing those with big turbo swap.
    – Steve
    2021 Tesla Model Y
    2020 Tesla Model 3
    2014 Dodge Grand Caravan
    Jun 15 2007
    Hillsboro, OR
    I don't really get on it while turning corners so I don't think that is the problem. Thanks for all your help guys. I'll post again when i find the answer out to the problem so maybe this can help someone in the future.
