Results 1 to 3 of 3
Thread: Tire Question
    Senior Member Two Rings Hootie's Avatar
    Jan 07 2007
    99.5 A4 1.8T qm
    Minnesota
    Tire Question
    Hey guys!
    I got new tires for my 18" summer rims on Christmas of '08. They currently have about 1 and a half summers on them, and the tread is hardly down at all from what it was. Last fall one of them was severly damaged and needed a replacement. Not wanting to deal with it, i just put on my winter tires early. They no longer produce the same tire as my other 3.
    My question is will my car drive different if i get the same brand of tire, different model and obviously same size, instead of buying 4 new ones? Is there any risk to this?
    thanks.
    Dec 05 2007
    The tire that was discontinued was more than likely replaced by a different (new) model. I would look into which model tire replaced it and go with that tire.
    Veteran Member Three Rings AvantJunkie's Avatar
    Jul 17 2009
    Too much shit.
    Longview, WA
    Quote Originally Posted by Hootie View Post
    Hey guys!
    thanks.
    I am in the same boat as you and was wondering this as well. If its not safe to do with just one tire, would it be ok to run two of the original tires on the back, and then buy two of the newer versions of the same tire and run them on the front? I realize that it is always recommended to run four matching tires, but if they are updated versions of the same tire, would it cause any drivetrain damage?
    **Brett**
    2002 A4 Avant 1.8TQM Brilliant Black/Platinum with some stuff.
    My car and I have a lot in common--we're both kind of old and slow, but still manage to look pretty fucking cool.
