Results 1 to 13 of 13
    Veteran Member Three Rings Tallbino's Avatar
    Sep 09 2004
    B5 S4
    Fort Worth, TX
    ? for those with rear o2's coded out
    As the title states, for those of you who have had vast or epl tune out your rear o2 sensors, do you have problems passing inspection due to readiness? I had mine coded out, but the readiness still says "failed or incomplete" for the o2's and for catalysts. Anybody in PA especially? Is readiness in vcds the same as readiness at an inspection station?
    thanks,
    Chris
    Bucknell University '10
    '11 Alpine White/Coral Red BMW 135i - Stock
    '01 Silver, Black/Silver Alcantara S4
    Vast St 3 Tune, AWE fueling, AWE DP's, AWE SMIC's, AWE st 2 clutch/lwfw, Bosch 044, JHM Solid SS, DBA 4000 slotted rotors, PBR Ceramics, APR SRT Cat-back, 034 snub w/bracket, RS4 mm, 32% tint, AWE Boost gauge, M3 lip spoiler, AWE DTS, SR Vogtland GT's, H-Sport Sways, Low temp thermoswitch, Greddy TT, Fan delete, Alpine CDA-9855 & Ipod hookup, JL 12w3v2 & JL 250.1, AWE Pedals
    Veteran Member Four Rings gearhead1186's Avatar
    Mar 17 2009
    02 S4, 02 M3
    Queens, NY
    mine were coded out by EPL and all I passed all my readiness tests.
    Veteran Member Three Rings schaefer921's Avatar
    Nov 25 2009
    2008 RS4 Daytona Grey Ti
    Westchester NY
    if you fail inspection.. do you still have to pay them anything...just wondering lol
    2015 Q7 S-Line Sports Edition Daytona Grey Pearl
    2008 RS4 Daytona Grey Pearl Ti
    Sep 09 2004
    B5 S4
    Fort Worth, TX
    Quote Originally Posted by gearhead1186 View Post
    do you pass your readiness tests in vag com or do you mean that you passed when you took it in for inspection? I'm not sure that they are the same thing. Also, did you have to drive it the 50 or 60 miles that you typically would have to for them to pass? Vast and I have been working on this for a while now, and i need to get my car inspected asap. any info you have would be very helpful.
    Mar 17 2009
    02 S4, 02 M3
    Queens, NY
    Quote Originally Posted by schaefer921 View Post
    in NY, you pay if you pass or fail.
    Quote Originally Posted by Tallbino View Post
    I checked my readiness via vagcom right before I took it in for inspection. didnt feel like throwing away 37 dollars if I was going to fail. you can either drive your car for a couple days or take the easy route and force your car to test the readiness thru vagcom. takes about 10 minutes and is kinda fun.
    Sep 09 2004
    B5 S4
    Fort Worth, TX
    Thanks man, I'll try the forced readiness route (since my car is a month out of inspection lol).
    Sep 09 2004
    B5 S4
    Fort Worth, TX
    up
    Veteran Member Three Rings Burningcoals's Avatar
    May 16 2004
    Washington
    Passed just fine with EPL removing rear 02's. I believe you can fail 2 readiness but not 3 and still pass. Something like that.. been a while.
    If you dont have a CEL you should pass period. If you have a CEL you will not pass.
    • Current: 2018 Audi RS3 - 2000 Audi S4 3L
    • B5 S4 FATS TiAL R770 2.06 FATS VIDEO
    • B5 S4 Pump GAS 5.7 60-130 92oct + Meth
    • B5 S4 4.7 100-200kmh 92oct + Meth
    Veteran Member Four Rings jamestown478's Avatar
    Dec 24 2008
    2000 S4 stage 2+ on meth
    Milwaukee
    I passed with my apr stg 2 software
    __________________
    2000 S4 SRM K24's
    2002 Audi TT, 225q
    2012 VW Tiguan
    2013 VW Jetta
    Veteran Member Three Rings DanS4's Avatar
    Oct 03 2008
    01.5 Audi S4, 00 golf Tdi
    Reading, PA
    yes passed PA inspection/emissions. run piggies without relocated 02s. (coded out) \
    SOLD Silver 01.5 S4 ; VAST tuned k04s, piggies, ASP exhaust, FMIC, Tracksports, DTS, ...
    http://www.socals4.com/
    Jul 26 2009
    00 S4, 01 S4, 93 RX7 LS1/T56
    Dallas
    Care to share how you do that by chance? I've only played around with Vagcom a bit, but didn't see a way to set readiness checks.
    Chris Sanders
    02 A4 Avant
    01 Noggy S4
    00 BB S4
    1993 RX7 w LS1/T56
    Feb 19 2008
    V8 powa!
    Texas
    Mosty states allow only 2 readiness tests not to run. I used to live in CA and that is how it was there. Just make sure all run but two. You probably had more than the 02 readiness that hadn't ran. Some of the 02 coding out does not allow the 02s to complete the readiness, so just make sure the others run. VAG-com is your friend for this.
    Senior Member Three Rings tsbpenguin's Avatar
    Mar 15 2008
    03 RS6 x2, 04 Allroad 6mt k04, 07 Tundra, 92 Legacy
    303 (CO)
    I passed after having EPL tune out the rear o2's. I don't know if other states are different but here in Colorado, they don't check for anything in the codes unless your CEL is on, and in that case you automatically fail. So as long as the CEL is off you'll pass.
