The error i Received was
SAE VAG Description
P0300 16684 Random/Multiple Cylinder Misfire Detected
Turns out to be Cyl 1 3 4
Misfire Detection
Fuel injectors checking
Ignition coils with power output stages checking
I have changed all the coils and spark plugs. Is it safe to say then its probably dirty or I need to replace the injectors?
ABS light
I get no error on OBD II scanner
ESP Triangle with"!"mark with a circle ( it goes off and on )
Using my EBahn DVD I found the censor for the ESP ( do I need to replace it? )
I hit the esp button on the console and nothing changes
Now the easy things I can figure out do not laugh
1. I have no owners manual and I do not know hot to reset the memory and set the memory for the car seat.
2. I can not find shhhh the trunk release button or maybe i have ( by the drivers door in the door panel ? ) Maybe its just not working.
Any advice is welcome
