Results 1 to 12 of 12
    Active Member Three Rings
    Nov 21 2008
    Romania
    RS4 lighweight pulley
    So in search for those extra ponies I took the stock pulley off and took it to a machine shop so they could make me one out of a lighter material.
    Pics and weight here : http://www.euroaddiction.net/forum/s...ead.php?t=1465
    NAZI MOD FAIL!
    Feb 15 2007
    Fail! Have to be a member of euroaddiction to view
    2007 Audi RS4 - Daytona Grey - Original Owner
    1957 MG MGA 1800 - Austin Healey Spruce Green
    2020 Mercedes-Benz GLC 63 AMG - designo Cardinal Red
    2024 Tesla Model 3 Dual Motor - Stealth Grey
    Aug 19 2008
    US (Al.)
    Yea....I signed up to EA a few days ago, but I'm continually getting kicked off......something about a security token that's missing? Anyway.....
    Veteran Member Four Rings two2's Avatar
    Jan 25 2009
    RS4
    Tri-state/CT
    i thought this couldn't be done due to the crank balancer?
    Veteran Member Four Rings jfunkey's Avatar
    Jan 21 2009
    R32 B7/S4....2000 2.7t gone :(
    putting you into the wall
    The RS4 and the S4 are two different motors.
    JHM war machine. Total transformation. JHM/Tune/headers/intake manifold.
    My B7S4. Faster then my old RS4 and First B7 S4 in the 12's
    AMA member
    USMC member (active)
    Facts first member. Built and supported by many
    Aug 14 2008
    '90 Cq - '13 R
    obamaland
    Quote Originally Posted by two2 View Post
    That actually makes it easier, the crank is fully internally balanced on the RS4. Therefore the LWCP can just be plain balanced, unlike the S4 piece where it is necessary to create balance with the crankshaft/rotating assembly.
    Mar 11 2008
    B7RS4 & e46Ms
    <<<would like to try out a LW crank pulley
    FRRG AZ Ring
    Nov 21 2008
    Romania
    I will let you guys know when it`s finished. After testing it on my own car and when I`m sure this won`t be a detriment to reliability.
    NAZI MOD FAIL!
    Nov 21 2008
    Romania
    A sneak peek to spark your interest :
    More info can be found here : http://www.euroaddiction.net/forum/s...ead.php?t=1465
    You have to be a member of EA to view the thread but considering it takes 2-3 minutes to sign-up I don`t think it`s that much of a biggie.
    NAZI MOD FAIL!
    Nov 21 2008
    Romania
    New pics. 2 of the pulleys were machined in such a way that balancing was not required.
    NAZI MOD FAIL!
    Aug 14 2008
    '90 Cq - '13 R
    obamaland
    Looks good, solid work.
    Nov 21 2008
    Romania
    Now at 1.2kg. Pretty big difference from the stocker (3.6 kg) .
    Imperial values : stock - 8 lbs ; aftermarket - 2.64 lbs.
    Don`t think there`s much point in racing after a 400 gram pulley , I mean gains from loosing 700-800 grams on the crank pulley can`t be easily quantifiable.
    NAZI MOD FAIL!
