in an attempt to activate TMPS in an A4 B8, I followed the Wiki:
MMI high (MMI 2G):
[07 - Control Head]
[Adaptation - 10] -> Channel 01
add 16 to the existing value
[03 - ABS Brakes]
[Security Access - 16] (probably with login code: 61378)
[Coding - 07] -> Long Coding Helper -> Byte 1
Bit 3 - Tire Pressure Monitoring (PR-7K6) active (1 = active)
[17 - Instruments]
[Coding - 07] -> Long Coding Helper -> Byte 4
Bit 0 - Tire Pressure Monitoring (TPMS) installed (1 = active)
finally I restarted the MMI.
in the menu CAR, there was an entry Tyrepressuremonitor.
however, this resulted in an tmps-error; both in the DIS as well as the warning-indicator
so, I returned above setting back to their original values.
and resetted the MMI again.
but the error remains.
did a complete error-scan with vag-com.
removed all errors, etc. etc.
any suggestions, as how to remove the error ??
thnks
