Results 1 to 6 of 6
    Deactivated Three Rings
    Oct 07 2008
    Santo Domingo, Dom. Rep.
    Codes after O2 Sensor replacement
    Saturday i replaced my front O2 sensor because gas mileage was crap. Vag'd afterwards to verify that everything was Ok and got these codes:
    16395 - Bank 1: Camshaft A (Intake): Retard set point not reached (over-advanced)
    P0011 - 002 - Lower Limit Exceeded - Intermittent
    17536 - Fuel Trim; Bank 1 (mult): System too lean
    P1128 - 001 -Upper limit Exceeded - Intermittent
    Any clues what this could be? Thanks.
    Veteran Member Three Rings daghstdrummer's Avatar
    Feb 09 2007
    2012, Honda CRV - 99 Ford E-150 Conversion van
    Astoria, N.Y.
    Quote Originally Posted by mr_esmit View Post
    16395/P0011/000017 - Bank 1: Camshaft A (Intake): Retard Setpoint not Reached (Over-Advanced)
    Possible Symptoms
    * Power Loss
    Possible Causes
    * Camshaft Adjustment Valve 1 (N205) faulty
    * Fuel Pump Relay (J17) faulty
    Possible Solutions
    * Check Camshaft Adjustment Valve 1 (N205)
    * Check Fuel Pump Relay (J17)
    Special Notes
    * When found in Engine: 4.0l W8
    o Check TPL 2010059(RoW)
    + Check/Replace Oil Sieve in Timing Case (Camshaft Adjuster)
    17536/P1128/004392 - Fuel Trim; Bank 1 (Mult): System too Lean
    Possible Symptoms
    * Malfunction Indicator Light (MIL) active
    Possible Causes
    * Mass Air Flow (MAF) Sensor faulty
    * Oxygen Sensor Control faulty
    o Oxygen Sensor(s) faulty
    * Fuel Injector(s) faulty
    Possible Solutions
    * Check Mass Air Flow (MAF) Sensor
    * Check Oxygen Sensor Control
    o Check Oxygen Sensor(s)
    * Check Fuel Injector(s)
    Special Notes
    * Additional Information on Fuel Trim
    I would check your maf first before the injectors since u changed your o2's
    2002 A4QM 1.8t Frankenturbo Tuned by SSP... R.I.P.
    135
    24R
    Feb 09 2007
    Astoria, N.Y.
    wiki.ross-tech.com is a great site to see what your fault codes mean.. i used it when i had the 17536 code it was my maf after i changed the o2's and all.. injectors can get expensive
    135
    24R
    Oct 07 2008
    Thanks for pointing me in the right direction.
    I've been looking at some threads on here regarding the camshaft chain adjustment (tensioner) valve. I see the mechanical part works with oil pressure. Any body think that if i seafoam my car & change oil the ticking might go away? How much does the valve/tensioner cost??
    Feb 09 2007
    Astoria, N.Y.
    the ticking might go away with seafoam treatment. as far as the valve tensioner i believe ecstuning.com will probably have it u can check there... shouldn't be too much they are decent with pricing.
    135
    24R
    Oct 07 2008
    Quote Originally Posted by daghstdrummer View Post
    Possible Symptoms
    * Power Loss
    Possible Causes
    Possible Solutions
    Special Notes
    Possible Symptoms
    Possible Causes
    Possible Solutions
    Special Notes
    Actually, I only changed the front sensor (bank 1). Do you think I might have to change the rear one also??
