2007 A4 2.0T auto. 30000 miles. I got a CEL "P0089 Fuel Pressure Regulator 1 Perform" and "P0441 EVAP Control System Purge Flow Fault". Rpm's were fluctuating around 2000 mark. After I read up on these forums I replaced the cam follower (06D-109-309-C) and new seal. It had slight wear on the follower but cam was perfect and pump shaft seemed fine too. But the code comes right back. I have replaced the low pressure sensor (06F-145-710-G) as well as the N80 valve(06E-906-517-A). Originally I had the P0087 code but after replacing the fuel pressure sensor (06E-906-051-K) it replaced with the current P0089 code. Other than the fluctuating rpm's when I am accelerating slowly there are no other symptoms. Any ideas what could be the problem?
