Results 1 to 13 of 13
Thread: 034 FMIC b5
    Active Member Two Rings Sharpy's Avatar
    Mar 06 2010
    Littleton
    Question 034 FMIC b5
    Hello i am installing 034 FMIC on my 2001 audi a4 1.8 quattro. i noticed the hoses right after the intercooler doesn't fit perfectly it bends alot make the path smaller will this affect my performance. if so i there anything i can do about it.
    Sharpy
    2001 Audi a4 quattro 1.8t
    Dec 05 2007
    What do you mean?
    Mar 06 2010
    Littleton
    like i am installing it and the rubber type hoses right after the intercooler has to make a sharp turn and it is not designed for the sharp of turn. so the hoses gets thinner. if that doesn't make it clearer i can take a picture.
    Sharpy
    Dec 05 2007
    I get it now. 034 is good at what they do, so I doubt it would make that significant of a difference. More of a crush effect of bending silicone. Usually with custom piping, people would use mandrel bend aluminum piping to have the same ID all the way through with no turbulance (other than at coupler joints). If you feel it a big concern, call 034 and inquire about it. They have really good customer service.
    Veteran Member Four Rings salz2135's Avatar
    Sep 15 2005
    Austin, TX
    Are you trying to install this using your stock bumper?
    Mar 06 2010
    Littleton
    Yes i am
    Sharpy
    Sep 15 2005
    Austin, TX
    That's probably the issue. I believe you have to modify your bumper/support to get that unit to fit correctly.
    Veteran Member Four Rings 97B518TQM's Avatar
    May 31 2009
    CA. USA
    Some trimming might be needed to fit everything.
    SOLD: B5 S4 Tial 770s with meth @652hp
    Current: C7 S6 - SRM +4mm RS turbos, SRM inlets, SRM fuel lines, DS1 stage 4 custom tune, HPFPs, X-pipe, H&R lowered
    Mar 06 2010
    Littleton
    I have done the trimming but that bend is there when i put the intercooler on the car with out the front bumber even there
    Sharpy
    May 31 2009
    CA. USA
    Quote Originally Posted by Sharpy View Post
    I meant trimming of pieces that get in the way of the piping. I had to do a lot of that to fit my custom kit. I would think that the 034 kit would fit in easier but these cars are kinda tight in some of those areas and need some trimming.
    Established Member Two Rings clubaudi's Avatar
    Dec 06 2009
    b5 a4, 03 gsxr,98 blazer
    west columbia/south carolina
    i took out the factory air pump(or whatever its called) and cut the hell out of the bumper support... i also had to make a little room on the hot side around the radiator support
    ATW A4 1.8T FWD
    Mar 06 2010
    Littleton
    When you took out that pump did it affect anything
    Sharpy
    Sep 15 2005
    Austin, TX
    Of course. The secondary air injection pump is part of the emissions controls for the vehicle. You'll have a CEL and depending where you live, you won't pass emissions.
