Results 1 to 13 of 13
    Active Member Three Rings spinall4's Avatar
    Jan 10 2010
    Buffalo, NY
    Help help help asap please
    So the car is stored for winter, i start it every 2-3 weeks without problems except i always have to jump it with my jumpbox. Today i jumped it and started up like always ran for about 2 min then just shut down. No hesitation or anything just like somebody had turned it off, now it wont restart and is making some clicking behind the steering column when the key is turned over and also sounds like the fuel pump is turning on and off as this clinking continues... (relay maybe)ANY IDEAS? my car is now in the street and have to get back into the yard as i cant park in the street yet
    BTW car is a 99.5 1.8tqm
    Nov 15 2009
    Derry NH
    Maybe your battery is completely dead. When you store your car, you should remove the battery. It shutting down though makes me think your ignition switch is bad.
    Jan 10 2010
    Buffalo, NY
    That would explain the noise from the steering column... But would i hear the fuel pump shutting on and off???
    Jun 30 2008
    Erie, Pennsylvania
    Sounds like you don't have enough voltage to keep the fuel pump and/or starter relays closed during cranking. As soon as the starter relay closes, the huge draw of the starter tanks the voltage, opening the relays, and repeating the cycle. Try getting some good jumper cables and a car to jump it. Keep the engine running on the jump car and rev it up a bit to get some more juice. Also, plan on buying a new battery. If it has been dead for that length of time it is doubtful that it will live again. Car batteries don't like to stay discharged, it tends to kill them.
    Jul 24 2008
    Belleville NJ
    Yep, Get your battery checked at your local auto parts store. See if it is dead.
    Jan 10 2010
    Buffalo, NY
    well got the daily hooked up to it charging away, i will see if it starts up in a little while
    Veteran Member Four Rings BASARAB's Avatar
    Mar 01 2010
    Farmington Hills,Mi
    Vag-com it
    Jan 10 2010
    Buffalo, NY
    Quote Originally Posted by BASARAB View Post
    Vag-com it
    dont have one
    Jan 10 2010
    Buffalo, NY
    well i left the audi jumped onto my other car running for over an hour and still nothing... all lights on the dash light up bright and everything but still hear the relay clicking and wont fire up... Could a bad relay do this clicking or could it still be the battery?
    Jan 10 2010
    Buffalo, NY
    Mar 01 2010
    Farmington Hills,Mi
    Just post in regional forum that you need help with vag-com and I am sure some people will offer to help. Or you can use this http://www.vagtoolfinder.com/ Its too much guessing without vag-com
    Jun 29 2007
    Raleigh, NC
    you need to take the battery out and go get it tested and probably replaced. sometimes batteries just go bad and can't be charged especially if they're old.
    is your battery serviceable? did you check the water level if it is?
    im 99% sure you just need a new battery....
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Jan 10 2010
    Buffalo, NY
    it was the battery thanks guys!!!
