Results 1 to 10 of 10
    Mar 07 2010
    WI
    2000 S4... should I buy?
    Hey guys,
    New to the forum here,
    I can possibly buy a 2000 Audi S4 with a 6 speed, 135,000 miles for 3000 grand.
    The down side is the car can only be driven a little ways before it overheats... I was thinking a headgasket at first BUT it does not leak any coolant. When warmed up, the coolant will gush out of the overfill. The waterpump was replaced 4000 miles ago by a Audi dealer so that is ruled out.
    Anybody think I should buy it and fix it up?
    any help would be appreciated
    Veteran Member Three Rings M.S4's Avatar
    Mar 04 2008
    '11 S4
    MN
    If you know anything about these cars yes.
    If you don't know anything about the 2.7t engine and all its problems.. no, you have no idea what you're getting into.
    EPL Stage 3 with a bunch of other crap.
    Veteran Member Four Rings S4UCE's Avatar
    Aug 21 2007
    Fairfield County, CT
    $3,000,000 seems a bit much for a 10 year old car...
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    ^^^LOL
    but to OP, these angine are very expensive to work on unless you do the work yourself. If you have no idea how to remove a cylinder head or know your way around these motors, dont get it. If you do or know someone that does, go for it.
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Established Member Two Rings s4wag's Avatar
    Feb 28 2010
    narragansett ri
    dooo ittttt
    Veteran Member Four Rings orttauq's Avatar
    Mar 11 2007
    8V S3
    tri state
    Quote Originally Posted by M.S4 View Post
    I still don't exactly understand this type of comment. You have to start learning at some point. You weren't born with the knowledge of problems the 2.7t has.
    OP, for 3 grand that's a good price for a running S4. Worst case scenario if you couldn't fix it, you would get your money back. But 3 grand is a good place to start.
    Dec 07 2008
    Harrisburg, PA
    Quote Originally Posted by auditokey View Post
    Hey guys,
    Could be as simple as a stuck thermostat.
    Veteran Member Four Rings P0234's Avatar
    Jan 11 2010
    Need a B5 Avant!!!!
    NoVA
    I'd say no. Once a motor has been overheated, its never the same. Do you have any other info from the PO on what has been going on? The fact that the waterpump was replaced before makes me more suspect, chances are something went wrong, it overheated that time, possibly the pump, and it took out the head gasket out. If you aren't doing all the work yourself you are WAYYYYY better off getting a well running car for a few thousand more.
    If you are still considering it, take it to a good shop for a good assessment, and ask them to put their emissions tester with the coolant tank open, if the headgasket is gone, it will register hydrocarbons coming out.
    Active Member Three Rings
    Jan 15 2009
    2001.5 audi s4 stage 3
    pennsylvania
    good price buy it fix it and youll be good
    Senior Member Three Rings Audiophyle's Avatar
    Jun 24 2009
    ABQ NM
    Quote Originally Posted by orttauq View Post
    I believe the comment was ment to mean the S4 is not a good platform for a beginning wrench turner, because it is far more complex than many other setups. The heating system in the S4 has more electronics than my Honda has under the hood. lol
