Page 2 of 2 FirstFirst 12
Results 41 to 65 of 65
  1. #41
    Apr 05 2005
    Casa Stg 3 S4
    evergreen state
    as would I. It would be awesome to convert my rs6 to manual some day.
    Past (in order): Hibiscus Red B5 A4 ,2003 Audi RS6, B6 s4, UrQuattro, Urs4, Nogaro sport B5 S4 avant, Silver stg 3 B5 s4, 2010 A6 Avant prestige
    Present: Casablance White stg 3 B5 S4 avant, 2002 Audi S6
  2. #42
    Veteran Member Four Rings SteveKen's Avatar
    Jan 11 2005
    Pittsburgh, PA
    I'm 100% there with the mechanical side: engine/trans adapter, custom starter, custom flywheel.
    I'll make a post hopefully within a few weeks when the kits are ready for prime time, as the prototype has been vetted, etc.
    Some info: http://www.audizine.com/forum/showth...=1#post5485045
    Steve
    2013 S6 • 2012 Q7 TDI S-line • 2010 GTI • 2001 Honda S2000 • 1977 Honda CB750 F2 • 1965 GMC 1500 WideSide
  3. #43
    Active Member Two Rings Matt@RavenMS's Avatar
    May 10 2010
    Long Beach, ca
    So am I 100% on mechanical side.... feels like a race to the finish.. best man wins... ;)
    Here the links to my pictures, enjoy.
    http://www.rs6.com/showthread.php/20...ed+manual+swap
  4. #44
    Apr 05 2005
    Casa Stg 3 S4
    evergreen state
    Good to see guys! Here is to hoping the finish comes easily to the both of you. Keep us updated!
  5. #45
    May 16 2008
    South Texas
    It would appear the engine block was modified to fit the starter it is not a direct bolt up as an extra hole was drilled into the block.
    Compare the 2 images.
  6. #46
  7. #47
    May 16 2008
    South Texas
    I doubt the 034 piece would work the A8 flexplate and RS6 flexplate quite a bit different.
    You also have to take into account any adapter plate used.
  8. #48
    May 10 2010
    Long Beach, ca
    Quote Originally Posted by Scotty@Advanced View Post
    As I replied on another Forum... I noted that i needed to make the hole to allow the upper part of the starter bolt to the tranny. This is not a Bad thing. or even going to affect the engine at all. When you take a car not design for manual Sometimes you have to make adjustments. this is not the first time Someone has to modified something to make is fit. when you buy Rs6 turbo for S4, you have to completely change the turbos to make them fit. No one ever says anything bad about that.
  9. #49
    Apr 05 2005
    Casa Stg 3 S4
    evergreen state
    I think he may have just been refering to how you said completely bolt on, and he is saying drilling the hole isnt exactly "bolt on". I dont think he meant to say anything was bad about that....that's what i got anyways. Keep up the good work!
  10. #50
    May 16 2008
    South Texas
    Quote Originally Posted by Matt@RavenMS View Post
    As I replied on another Forum... I noted that i needed to make the hole to allow the upper part of the starter bolt to the tranny. This is not a Bad thing. or even going to affect the engine at all. No one ever says anything bad about that.
    I never said nor implied it was bad, just that term "Bolt On" was not correct.
    BTW How many bolt holes line up on the RS6 engine and S4 trans?
  11. #51
    Veteran Member Three Rings norsecarnut's Avatar
    Sep 15 2008
    2 Land Rovers, BMW E61 mt6
    why do useful threads just die.........?
    2008 S4 Avant mt6 Dolphin - APR Full exhaust / Escort 9500ci-stealth install / backup camera / aux-in & ipod & cd / 35% ceramic / 2" hitch class 2 / Nokian WRG2 / HID fog / Stasis high-bias center diff
    AKA: jwest
  12. #52
    Jan 11 2005
    Pittsburgh, PA
    Quote Originally Posted by norsecarnut View Post
    Do some searching on RS6.com.
    The 6spd RS6 I built was recently sold after I put about 12k miles on it.
    It was a great car/driver and I'm planning on doing it again soon. Just bought an S6 wan plan on swapping out the RS6 drivetrain and adding the 01E.
    Steve
  13. #53
    Veteran Member Three Rings Castor Troy's Avatar
    Dec 17 2008
    Billings, MT
    My S6 could use another 200hp...
    Quote Originally Posted by SteveKen View Post
    AEB: Boost goes in, valves come out.
    2003 Audi S6
  14. #54
    Feb 07 2008
    The boonies, near Seattle
    Do you do build threads? And what color did you find?
    -dre
  15. #55
    Nov 12 2010
    Vancouver, Canada
    This is exactly what I am hoping to do in the next year or so. Purchase an S6 and manual conversion.
    Since you've done a manual conversion already, I've got a few questions for you, if you dont mind answering.
    Can we use just any 01E transmission? Are they all the same from the inside out?
    Most of the conversions I saw were done using 01E on 2.7T, and if I remember correctly S6 came with a manual version in Europe as well.
    Would that be a better transmission to use? Or that IS the 01E tranny on the S6? What about the 0A3 transmission used on b6/7 S4s?
    Thanks in advance, Cheers
  16. #56
    Nov 03 2011
    All Over!
    Quote Originally Posted by wayne6213 View Post
    All 01E 6-speed manuals are the same. The internal ratios may differ, but the castings are the same, at least in terms of bolting to the block, and bolting on mounts. There are different mount options depending on what chassis the trans is destined for.
    The 0A3 6-speed manual from the B6/7 S4 will bolt to an 077 V8, but it uses a different mounting system to fit the later platform. It uses a DTS-style single cradle, that bolts underneath the trans case. I'm not sure if the casing has provision to bolt B5/C5 brackets to the sides.
    If you use the correct flywheel and clutch, you won't need an engine-to-tranny spacer either. The Audi engine hangs far enough ahead of the suspension as it is, you certainly don't want to add any more.
    1986 Type 85 Audi 90 quattro
  17. #57
    May 16 2008
    South Texas
    The 01E external dimensions are similar, there are a few subtle differences throughout the years however. Early cases (pre 1998) have the bolt pattern on the bell housing differing by two bolts and a dowel pin. The later transmissions also have provisions for the heat shields installed over the front axles, versus below for the earlier transmissions.
    The gear ratios also differ as well, there are 3 choices for final drive and several other choices for 1-6 ratios.
    I've put together a swap kit using a rebuilt tdi transmission for ~$3500.00 shipped for a few other list members. If you go the used route keep in mind that the 01E's are pretty problematic in regards to the 1-2 collar and fixing that costs ~$1100 plus labor.
    The 0A3 is a different transmission entirely.. As Siena stated. The trans mounts differ, the shifter differ, there is only one style of output flange on the axles, the bolt pattern differ slightly and there are no provisions for a speedmeter pickup on the 0A3.
  18. #58
    Nov 12 2010
    Vancouver, Canada
    Wow!
    Nollywood and Scotty, thanks for the super informative replies!
    I will keep you guys updated if I ever around to doing conversion.
    Love the C5 widebody to death.
    Again, I really appreciate your inputs, a big thanks to you guys.
  19. #59
    Veteran Member Four Rings DiscoPotato's Avatar
    Sep 16 2009
    Delray Beach, FL
    Why not just use a b7 rs4 trans?
    1996 A4 - Rolled into the woods
    2001.5 S4 - Stolen
    2001 STG3+ S4 - Sold
    2011 M3 - Blown up
    2017 S3 [11.990 @ 112.38mph] - Current
  20. #60
    May 16 2008
    South Texas
    Quote Originally Posted by DiscoPotato View Post
    No provisions for C5 style transmission mounts
    No provisions for speedometer sender
    Inner axle joints are the later small tripod style, limiting choice of axles.
  21. #61
    Sep 16 2009
    Delray Beach, FL
    I could have sworn I saw someone in Australia swap in a B7 RS4 Trans.
    Not sure what he modded.
    2001.5 S4 - Stolen
    2011 M3 - Blown up
  22. #62
    May 16 2008
    South Texas
    Don't get me wrong, it's possible to put the 0A3 trans into an earlier car you just have more issues to deal with. Rumor has it the famous Sportec car that was illegally imported used an 0A3.
  23. #63
    Established Member Two Rings S is for Slow's Avatar
    Dec 08 2013
    00 n 01 Nogaro S4, 14 S4, 03 Freelander, ZX-12R, GSXR600, CBR1000RR, Jawa Golden Sport,
    Des Plaines, IL
    Yup should be starting my buddies RS6 manual swap next week all the parts will finally be in. Looks good. Keep us updated.
  24. #64
    Nov 03 2011
    All Over!
    Did this swap get completed?
  25. #65
    Active Member Two Rings MidDee's Avatar
    Dec 21 2016
    Portland Oregon
    A Lot off these threads need to be revived.
    I too would like to see the result of this.
