Results 1 to 13 of 13
    Nov 29 2007
    Calgary, Alberta, Canada
    Signs my turbo is about to crater?????
    Can anyone tell me what the signs are right before your turbo bites the bullet? I have smoke on startup oout the tailpipe when the car sits for a few hours, which is weird I just had the timing belt, water pump, tensioners, valve cover gasket, timing chain half moon gasket and intake breather hoses changed on my car???? Now my turbo is wheezing, like a drill sound from under the hood when I go into boost range, and slightly before boost range?
    Aug 17 2009
    Pittsburgh
    your turbo is toast if its making those noises.
    Veteran Member Four Rings MMMB00ST_A4's Avatar
    Mar 31 2009
    NC
    "Dentist drill" sound. Your turbo is gone..Sadly, so is mine ='(
    -Brandon
    APR | Oettinger | KW | iForged | Evolution Racewerks | Labree | Carbinio
    12.9@104mph
    Nov 29 2007
    FAAAAAAWK... Oh well on a lighter note I have my 3K saved to do a K04 upgrade with Eurodyne flash... thinking about an evolution racewerks aluminum TIP, what cold air intake do you guys suggest?
    Aug 17 2009
    Pittsburgh
    if you have 3k saved up, do better than a k04. get a gtrs eliminator for 1500, software for 500, and injectors for 300 and spend the other 700 on whatever you want and have 100 more hp than the k04.
    Mar 31 2009
    NC
    Quote Originally Posted by hercfe View Post
    Not that easy. You're assuming he already has a good enough FMIC for the GTRS, and not still running stock exhaust. And i would either go with a Carbinio intake or no intake. Nothing in-between.
    -Brandon
    12.9@104mph
    Veteran Member Four Rings wolfdog's Avatar
    Nov 22 2006
    Dentist drill is the tip off to a dying turbo. Skip the intake, I'm surprised how many people want to mess with that with so many other things they can do. I'd also skip the aluminum TIP (at least as an initial mod) if you decide to stick with a KO4.
    2002 A4 TQMS
    Motoza 1+ w/Genesis 380s, 034 HFC, K&N drop-in, 710N, Neuspeed snub, StopTech SS lines w/Hawk HPS, Conti DWS, full Votex, Pioneer FH-X700BT, DDM 35W 4500K HID
    12/23/09 - My car has been phenomenal to me. Runs strong. Don't think I'm ever going to sell it. Rather throw $7k into it for a refresh than buy a new A4 that has no dipstick.
    12/5/10 - 100k miles & counting!
    9/22/13 - 146k+ & running strong w/a new TB, water pump, etc.
    Senior Member Four Rings spector's Avatar
    Sep 08 2009
    SE
    I imagine he'll have to pay someone to install that? What's a turbo install, like 1g?
    Nov 22 2006
    Labor is a wash if his turbo absolutely needs to be replaced and he's looking at a KO4 and an eliminator.
    2002 A4 TQMS
    Sep 08 2009
    SE
    Quote Originally Posted by wolfdog View Post
    Indeed, but it still needs to be counted in the 3k. Depending on how much a turbo install costs, that could be more than he has for an elim.
    Mar 31 2009
    NC
    Screw labor. Link him to the KO4 or Elim. DIY. It is such an easy job. Not the easiest, but it only takes basic knowledge for the most part. Im too lazy to link him =)
    -Brandon
    12.9@104mph
    Deactivated Three Rings
    Nov 28 2009
    taxachusetts
    turbos are a bolt on, grab a bentley manual and many of the DIYs on here and bang it out over a long weekend.
    Nov 29 2007
    Labour is a non issue, my mechanic buddy is bolting it on for me, then we will tow it to get flashed. Im not interested in GT28R turbo, Im not a track guy and I dont want turbo lag all the way up until almost 4K RPM, that does not appeal to me at all. I would be happy with a solid 247CHP in my everyday driver.
