Results 1 to 13 of 13
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Frisco, TX
    Metal window trim oxidized
    The metal trim around the windows on my B6 S4 is oxidized. Previous owner was responsible for this. It's definitely cloudy with some weird rainbow effects. I tried using Klasse All-In-One and Meguiar's ColorX (both are oxidation removers) but the oxidation will not come off.
    It's my understanding this metal is clearcoated, so it should be treatable like other painted surfaces. However, when using the Klasse, the cloth I buffed with came out as a black color...as if the metal is not clearcoated.
    Can anyone shed some light on how to deal with this?
    now: 2021 Mercedes AMG C63 S, 2017 Chevrolet Corvette Grand Sport
    past: 2005 Audi S4, 2011 Audi S4
    Veteran Member Four Rings nadroj81's Avatar
    Feb 12 2004
    Albany
    same happened to my a8l. it is non-treated aluminium from what i have been told. I have fixed it, and sealed it and it will still come back over time. Probably really needs to be buffed down far.
    Apr 24 2009
    Frisco, TX
    So it is NOT clearcoated after all. Sounds like I need to just tape off around the metal, whip out the orbital buffer, and put some metal polish on there.
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Apr 24 2009
    Frisco, TX
    Thanks. Looks like I need something more abrasive. Was hoping to fight it chemically but that may not work. I have some ScratchX that's worth a shot. Otherwise, it's time to break out the cutting agents.
    Veteran Member Four Rings rlarsen462's Avatar
    Jul 07 2009
    Varies
    Have a B7 S4 with the same problem, dying for a solution. I suspect sanding aggressively with 1500+ sandpaper will remove the haze (and clearcoat), and then you could repolish, but it will be a pain to do on the car (trim is hard enough to remove that if you remove it you might as well replace with new). Of course if you remove the clear coat, you're going to have to protect it or polish constantly.
    Can anyone confirm a solution to the "rainbow, hazy, cloudy" looking trim that brings it back to polished rather than a brushed look (like you'd get from sanding)?
    2025 Porsche Black Olive RS6 Performance (inbound)
    2023 Tango Red R8 GT (inbound)
    2023 Daytona Gray SQ7
    2021 Tango Red RS5 Sportback (Sold)
    2013 Daytona Gray RS5 (Sold)
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Read above. Click my link. It's not clearcoated. EDIT: saw you already commented on that post.
    Don't sand it. Hit it with an abrasive polish, then finishing polish. Couple coats of wax and you're good to go. Try this before you go at with sandpaper, that should be a last ditch effort.
    Jul 07 2009
    Varies
    Yeah I will mask off and go to town with with a 105/205 combo, hope it improves. I will document the process since I know there are a lot of people with shitty looking trim like mine and this might be the wonder cure we've all been looking for.
    Apr 24 2009
    Frisco, TX
    Reviving this because I finally bought some M105 and went at it yesterday. There was virtually no change.
    I am contemplating going after this with 0000 steel wool. Thoughts?
    Senior Member Two Rings readimag's Avatar
    Jun 28 2008
    2000 s4, 2011 acadia, 2010 s4
    Savannah, GA
    Quote Originally Posted by dparm View Post
    What did you use to help polish with the m105, I used mothers alum and mag polish worked for me.
    2000 s4
    Apr 24 2009
    Frisco, TX
    What do you mean, exactly? I used the M105 by hand several times and there was zero change.
    Jun 28 2008
    Savannah, GA
    I would tape it off and use a PC or rotary see if that works also by hand you need lots of pressure.
    2000 s4
    Apr 24 2009
    Frisco, TX
    I have a random orbital, it's too awkward to hit those strips since they're angled and thin.
