first 2 boxes are 3rd gear wot runs after shifting from a higher rpm in 2nd gear. third log is a 4th gear cruising log starting at ~38mph, then going wot to 70mph.
still need to increase n75 duty cycle some considering actual still does not meet spec boost (closer than it was though). highest actual boost is 2290mbar, or ~18.5psi.
0 timing pull pretty much. i need to log actual timing to see what it is.
i really want to buy a test pipe and a used k04-015 if anyone has one for sale. :p
